Ford Interceptor Paint color/code |
Post Reply | Page 12> |
Author | ||
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 918 |
Posted: April-08-2015 at 4:39pm |
[/QUOTE] Brian,
The ply used for the hull are scarfed from 8' sheets. To do this properly, the face veneer needs to be about 1/8" thick to allow for sanding the joint to blend for the bright finish. Besides the delam on my X, the inner keel was also full of rot.[/QUOTE] Scarfed. I thought you were using 'slang' for "harvested", or "scavenged". I've since learned that it is a wood-joining technique. Fascinating stuff. Thanks Pete. |
Brain,
The ply was scarfed and nicely done. The blend line,was smooth and hard to see unless you went looking for it. Yes, I didn't know I had a problem with rot in the inner keel until I pulled the engine for flipping the hull. I did suspect it since the ply at the keel rabbit at the engine showed some signs. The keels were White Oak and I've seen one that was Ash. |
MourningWood
[/QUOTE] Brian, The ply used for the hull are scarfed from 8' sheets. To do this properly, the face veneer needs to be about 1/8" thick to allow for sanding the joint to blend for the bright finish. The problem is finding ply with that thick face veneer, The special ply Dunphy used came directly from a Philippians supplier. It was also the root cause of the delam since the ply used had a funguss so as soon as it got damp, it went bad. Besides the delam on my X, the inner keel was also full of rot.[/QUOTE] I'd love to know if the side ply was butt-jointed or what? With all the resources around Tahoe, surprisingly little Dunphy info. I guess very few X-55 made the trip West. I, too suspect keel rot, and will poke around there while the motor is out. Thanks for all of you taking time to post on this "off-topic" subject. |
MourningWood
Nice boat, Pete!!!!! My goal!
Here's one of mine....don't have many pics, took a lot at Tahoe, dropped phone in Tahoe. |
skutsch
Grand Poobah Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
Yep, just thought I'd make it easier for everyone... |
Steve,
Thanks. I did watch the video when Brian posted it. |
skutsch
The youtube video mentioned above:
This fix came directly from John at Y blocks forever. |
Brian, The ply used for the hull are scarfed from 8' sheets. To do this properly, the face veneer needs to be about 1/8" thick to allow for sanding the joint to blend for the bright finish. The problem is finding ply with that thick face veneer, The special ply Dunphy used came directly from a Philippians supplier. It was also the root cause of the delam since the ply used had a funguss so as soon as it got damp, it went bad. Besides the delam on my X, the inner keel was also full of rot. |
MourningWood
Me thinks this guy Riley knows his Interceptor Y-Blocks....thanks! |
MourningWood
Soaked oil pan in solvent tank for a bit, and lo and behold, it took off the "sprayed-over" color and revealed the original paint. Greener than currently. It appears to have originally been painted over a white primer, and very durable. I'll have some mixed and post it here.
MourningWood
Perhaps. I've seen restrictors in place there. At Edelbrock we do it differently. Yes, I would like to re-do the bottom too, but then, why not the sides, then maybe the keel, and so on, and so on, ands on....... He also cheaped the sides, by skinning over the original ply, but with only 8 foot lengths, resulting in vertical seams. Plus, the stain is too dark. So when I can find a supplier for the correct-sized plywood, I'll re-do it all correctly. Until then, I can do my motor work. Besides, it comes out in about 90 minutes. |
That's a very nice restoration except I'm surprised he did a back yard hack job on the bottom by fiberglassing it. The ply delamination is what put Dunphy out of business with the X55. I put a complete new bottom on mine. |
The oil problem is solved by plugging the oil hole at the aft end of the rocker shaft.
MourningWood
Yes, they do have oiling issues, mostly related to sludge buildup in the passages and return tubes. Modern oils have all but eliminated this issue. The other common oiling concern is inadequate oiling of the rocker shafts, remedied by enlarging the oiling groove in the camshaft. But because I am doing a "bare-metal" repaint of the engine and trans, thought it a good time to take a peek inside.
63 Atom Skier
Newbie Joined: August-21-2012 Location: Grand Rapids Status: Offline Points: 36 |
Note low oil pressure was common with the y-blocks. I have a 256 Y-block in my '63 Atom, which could probably stand a rebuild, but after doing a ton of research found that it wasn't uncommon for the old automotive y-blocks to throw on the oil light due to low oil pressure at idle.
Jason
MourningWood
Thanks again, all.
With your help, have confirmed it RH rotation. Which, for a Ford, means 'reverse rotation' So now I can keep going. Will replace bearings and rings at minimum, refresh heads. Other than leaks, and low oil pressure, no real issues. |
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7957 |
The numbers on the front cover indicate what engine, transmission and rotation it was from the factory. R or L is for left or right when looking at the engine from the rear. The info is only accurate if no changes have been made. If you haven't pulled the engine apart, whatever rotation that makes the distributor rotate counter clockwise is the correct rotation of the engine. We've got 2 Dearbo C transmissons, one which needs a rebuild if we ever get around to removing it from the engine. There's a manual for Interceptor Y blocks in the reference section if you haven't seen it.
MourningWood
Thanks guys for the replies. Good group here.
Pete, it has a Dearbo "C", works well but rear seal leaks, and shifter needs adjustment. I think the firing order is on the front cover, maybe I can check that. I do have manuals. Also, the phone with all my photos from Tahoe is, in fact, at the bottom of Tahoe. There is a video of the boat on Youtube...."Dunphy X55-Reno NV" for your viewing enjoyment. |
Riley
Pete, with a Y block doesn't a RR have timing gears and a standard rotation a timing chain, so pretty easy to tell for sure?
It's a RR. What trans is on it? Dearbomatic or Velvet?
MourningWood
Yes, the prior owner used a reasonably close Chrysler blue spray bomb, but I want to do it better.
Also, not to screw up my own post, but I realized I've never noted the engine rotation before starting teardown. Is this a standard, or a reverse rotation engine? |
juniorwoody
Gold Member Joined: August-09-2011 Location: Oak Hill, Fl Status: Offline Points: 937 |
I did just get Sherwin Williams to custom mix some paint for our AMC 327 engine as a custom match. They did a good job and the oil based paint had pretty good oil resistence so I think will hold up well as an alternative to impossible to find colors for marine engine blocks. Time will tell.
The value of money spent on new adventure far exceeds the value of money saved for the future
Riley
Somewhere, there's a can of this on someone's shelf.
Tim,
Thanks for finding that old tread. The Sea Foam green I found back then isn't the answer ether. I pulled the sample I sprayed and it has darkened with time past the color of my aged 312 color. It is more green without the blue tint and yes, under different lighting shows up different. I thought I had it out of an off the shelf but now feel a custom mix is needed. The time will come when my 312 needs a rebuild but that's way down on my to do list. I hope I'm still alive when that time comes! Speaking of lighting, I did use 5000 kelvin and the highest CRI florescent lamps in my shop build to try to overcome the color problems. |
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=12408&PN=1&title=paint-color-for-interceptor-engine
Did he even come close to the original color? |
MourningWood
I searched "interceptor Paint" here, but came up dry.
Thanks for the tips. Yes, it is the pale greenish/bluish color. The previous owner spruced it up with a quick spray, covering most of any clean original color. I'll keep looking as I disassemble it. Thanks |
Brian,
There isn't a standard color that matches. The closest anyone has ever come to it is Reid when he rebuilt his 390 and word is he had it mixed. Alpine or Vista Green IS NOT the proper color no matter what anyone says! |
