  New Posts New Posts RSS Feed - Broken steering cable
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Topic: Broken steering cable
    Posted: May-22-2015 at 1:40am
Originally posted by phatsat67 phatsat67 wrote:
Originally posted by storm34 storm34 wrote:
Remember to pull the new cable up through the bilge. Makes life much easier. Trying to force it down from the dash doesn't work.
+++1^^
Also, the new cable nuts I don't believe are fixed. If it moves down the cable duct tape it to the end so you don't have to fish it through later. That's basically impossible.
Of course I read this when I came home, after the job.
The nut was -indeed- not fixed. I found out after I pulled the cable through. Pulled it all the way through though, with a rope attached to the end to pull it back.
I pushed the cable from the bilge/pulled under the dash. No problems there. Just took a while to adjust the steering wheel to a (kind of) straight position. Good to go again!
How long do steering cables normally last btw? Mine lasted about 3 years I think. Expected it to last much longer.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2015 at 3:14pm
+++1^^
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2015 at 2:36pm
Replaced one last week thanks to Zach.
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2015 at 2:00pm
Had a friend coming down to CR from Miami yesterday who brought it for me from Miami Nautiques. I should be wakeboarding this afternoon again! :)
Thanks folks!
xarmypilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote xarmypilot Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2015 at 1:23pm
Originally posted by tryathlete tryathlete wrote:
Call Zach at N3, he will cut you a Correct Craft Fan 10% discount deal!
And Zach will ensure you get the correct cable, not a 17' one that will "sorta work"...
'87 SN 2001
'68 Chris~Craft Grand Prix (Past family boat)
'72 Checkmate Mx16 (Past family boat)
"Speed is life, altitude is life insurance"
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2015 at 6:17am
2008 MasterCraft 197TT
1996 Nautique Super Sport
1988 Waterlogged Supra Mariah
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2015 at 12:46am
Hi, thanks. Yeah checked there and that all seemed to be OK.
Any tips where to get the cable?
hotboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2015 at 4:00pm
Make sure the clamp block is secure to the cable, it should be under the removable rear floor section I believe
Brian
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2015 at 2:33pm
I'm pretty sure that the steering cable on my '85 2001 snapped.
I checked the rudder and it's still connected. If I pull the rudder 'in' the steering wheel turns. If I then turn the wheel the rudder goes 'out' again, but then won't go back in.
Anything else it can be, anything I should check, before ordering a new cable?
And any store/dealer where the cable is less than $300?
