  New Posts New Posts RSS Feed - 1985 Water Intake
1985 Water Intake
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: 1985 Water Intake
    Posted: June-15-2015 at 12:04am
Jeremy,
Make sure you post some pictures.
H2oXtremes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H2oXtremes Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2015 at 11:47pm
The nut I meant not bolt. Looking at it today it looked like maybe the fiberglass wa molded around it. These projects are new to me. I'm just surprised there isn't more reinforcement on the inside of the hulll where it's compressed by that nut.
1985 Ski Nautique 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2015 at 11:25pm
Originally posted by H2oXtremes H2oXtremes wrote:
Tackling this project tomorrow, so unscrewing that bolt inside the bilge the entire assembly I assume will just fall out the bottom of the boat. There is no fiberglass issue to be cautious of its not fiberglassed into the hull?
Bolt? I've never see them bolted. Just the pipe thread locknut.
It probably will not fall out. They are bedded so depending on the condition and type of compound, some persuasion may be needed. It is not glassed to the hull. Do check for wood reinforcement around the hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote H2oXtremes Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2015 at 10:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2015 at 10:10pm
It's not at all complicated. Some do have some auxiliary screws but it's basically a pipe lock nut holding the pickup to the hull. If your boat does have some wood reinforcing the glass around the hull, you will need to address that since chances are high that it will be rotten and will need replacing. The pickup is bedded to the hull and I suggest using 5200 or at least 4200. NO SILICONE!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote H2oXtremes Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2015 at 9:33pm
My 1985 Nautique has always gotten some water in the bilge area for years and assumed it was just the stuffing rope going bad, I replaced the rope and everything is good but the water is still coming in the Bilge. Further inspection I noticed the water pick-up in the hull has a slow small stream of water coming from it when its in the water. Has anyone ever removed this piece from the hull and is this complicated to reinstall?
