Shaft aligh ment |
steve a
Groupie Joined: November-08-2014 Location: California Status: Offline Points: 44 |
Posted: June-22-2015 at 10:29pm |
Thanks I appreciate it I ck out CCF 101 SHAFT ALIGHMENT VIDEO .I believe that what was said on video but not sure . Thanks Steve
Steve,
Since yo got .011 and .014, that's the .003 max so you're good. |
steve a
I just replace cuttless bearing installed a doubletaper shaft while I am at it I should ck the alighment to the shaft . What I got was .011 lowest read and .014 highest read on my gauges . I have heard though video on Cc fan sites it needs to be. 003 of and inch variance to have proper alighment . I believe or hope that I am right . I did ck top to bottom and side to side bottom was the hardest the get . Also with the new shaft was not able to get safety ring on doubletaper shaft I don't believe it as nessary the old shaft was press on by factory my why new shaft has locking nut attached to the shaft holding the coupling . Thanks Steve
