  New Posts New Posts RSS Feed - wiring diagrams
wiring diagrams
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Topic: wiring diagrams
    Posted: June-03-2006 at 12:59am
Jeff....I hear your running! Great news!
Let us know how it does on the lake! I know your speedo was not working ...I have a hand held GPS you can take out if you want to gage your speed...call me if you want to use it!
GH
stang
The Super Air
scharf69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scharf69 Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2006 at 4:20pm
fixed!!!!!
just do it, do it, do it, do it
Post Options Post Options   Thanks (0) Thanks(0)   Quote scharf69 Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2006 at 12:49pm
Ok
I have one purple wire with a black stripe, and a black and white wire together. which would be positive and which is negative?
And also two wires from the distributor which I think red is positive and black neg right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote scharf69 Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2006 at 12:29pm
Thanks I'll give it a try.....
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2006 at 12:08pm
theres a wiring diagram in the service manual in the refernce section here, hit the link on top of the page that says reference.
there are two purple wires that go to the ballast resitor and the postive side of the coil, and a gray wire that goes to the neg side of the coil. there's only one heavy gauge wire by the wiring harness connector on the rear corner of the engine that is grounded to the block, beside the neg bat cable. You will also have two wires or one if points from the dist to the coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scharf69 Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2006 at 11:48am
My motor was taken apart and rebuilt by someone and I did'nt take a picture or label the wires from the coil to the ballist resistor blck and when I wired it up it was wired wrong and I fried the resistor. I am trying to find someone who would know the correct order for the 4 wires from the coil to the blk?
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2006 at 7:25pm
Jeff,
Shoot an email to Jeff Kostis(see member list)...he has a couple mustangs...chevy OMC.
Might be able to guide you though.
stang
The Super Air
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2006 at 2:15pm
No clue on where to find an OMC wiring diagram, but usually marine wire color coding is the same for all engines. What are the colors (and aproximate size) of the 4 wires you have left to connect? Also, what are their general locations? Maybe we can help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scharf69 Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2006 at 2:21pm
where could i find a wiring diagram for a omc 350. just rebuilt my motor and now im down to 4 wires
