  New Posts New Posts RSS Feed - hummingbird hdr 610
hummingbird hdr 610
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Topic: hummingbird hdr 610
    Posted: June-01-2006 at 11:56am
...and to expand, do not place the transducer behind any thru hull fittings as the turbulance (sp?) will interfer with the readings. What 2_Nautiques said about finding a good spot is important because air bubbles within the fiberglass laminate of the hull will interfer in accurate readings. So test any location first.
2_Nautiques View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2_Nautiques Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2006 at 9:36am
Dan, If possible install the sounder and connect as 79 stated. Then put the boat in the water. Use a plastic baggie filled with water to set the transducer on at the location that you want to install it. If the sounder is working properly, then this location is OK to glue the transducer down. If you do not get a good reading you must find a different location by moving this set up around the bottom of your boat until you get a good reading.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2006 at 8:08am
any keyed postive wire will work, don't use an acc you don't need the finder on if your not moving or the engine is off.
dans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dans Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2006 at 8:38pm
Just got the new 610 today . I noticed in the featured products on this site it was mounted close to the water pick up (opposite side). Is this the best place , or by the drain hole under the oil pan like some people did ? Any tips on power supply wire on my 82 2001 would be helpfull . My stereo acc wire is already hooked to ignition wire . Thanks ! Dan
