  New Posts New Posts RSS Feed - Fuel Line Connections - Sealers
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Line Connections - Sealers
    Posted: March-31-2016 at 2:25pm
Tom,
Tim is correct on no sealant on the actual flare fitting but, it won't hurt on the actual pipe threads say on the other end of a flare adaptor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2016 at 1:58pm
If double flared, NO. The threads are not the seal and may prevent the fitting from fully seating.
td_in_nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2016 at 1:53pm
I just want to make sure that the threaded gas line fittings at the fuel pump, filter and fuel rail do not need a sealant such as Permatex Aviation No. 3. Looking on line it appears some people do add the permatex to the threads if the connections. I do not think it required, but do not want to take any chances.
Thanks
Tom
