  New Posts New Posts RSS Feed - WTB- 50" x 1" shaft
WTB- 50" x 1" shaft
CCNewb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCNewb Quote  Post ReplyReply Direct Link To This Post Topic: WTB- 50" x 1" shaft
    Posted: June-16-2016 at 3:13pm
Talked with skidim. 10% off with their promo code. $413.00 + $35.00 shipping. New design in the last year. I would need the whole kit. Part number 1901. Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCNewb Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2016 at 2:24pm
10% off for being a member here!? I was looking at prices between 5-6 hundo online. I called skidim for a price. Still waiting for a call back. If I had a cream puff vessel I would buy a new one. Mine probably has close to 100,000 hours on it. Thought it might be helpful to others with piles of bent shafts too??
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2016 at 12:50pm
Originally posted by CCNewb CCNewb wrote:
Heading to Back to the Fifties in Minnesota today. Figured there's way more boat people there. So I started calling around and found a prop shop who has a machinist who is going to straighten my bent driveshaft!!! Basically drop it off tomorrow and pick it up next week before leaving town. It'll be $250 labor. It's called Formula prop and marine. I will post the results. Should be around half the price of a new shaft.
Cheers
This math is suspect. Subtract 10% and you're at $370 for a dual taper ARE from SkiDIM.
http://www.skidim.com/mobile/ARE-SHAFT-SYSTEM-1-X-4-COUPLER/productinfo/WS%2D2000/
Post Options Post Options   Thanks (1) Thanks(1)   Quote CCNewb Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2016 at 12:44pm
Cheers
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2016 at 11:28am
I have a single taper shaft out of a 80 SN with coupler. Measures 50-1/8"
You will have to pull motor or at least lift high enough to slide shaft from inside to install.
$75 plus the ride.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCNewb Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2016 at 1:09pm
Anybody heard of Turn Wright Machine in Cape Cod? Talked with him yesterday. Half the price of new shaft. He has a bunch of you tube videos. Wish there was someone closer who had the skills to straighten. How do I post pics?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2016 at 7:01am
Matthew,
Stick with the double taper ARE shaft. If you went back to a single taper you would need a new coupling half.
Welcome and how about some pictures of the 74!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCNewb Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2016 at 1:50am
I have a 1974 SN with a bent shaft. Currently it's an A.R.E. Shaft system. 50-1/8" x 1". Can I run a stock shaft without the stock couplers?
Thanks
