ballast resister,PCM breakerless Prestolite Dist. |
dip
Senior Member Joined: August-29-2009 Location: Eastern PA Status: Offline Points: 392 |
Posted: September-07-2016 at 8:39pm |
Call Vince at Discount Inboard Marine. I'm sure he knows. He told me to look for 1.8 on my 93, if I recall correctly. They are the best customer service I've ever had anywhere.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Attaboy Hollywood You're much better looking though If you really want to feel like me, you have to cut a coil apart to see what's inside I have pictures of the inside of one, I think I put them here on CCF. I'll have to look for them. For Tall Tex you should put a link to your find for the rest of the world to see and learn from It might look like the one below Bake's online 302/351 ignition |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13513 |
damnit. I measured the 87 PCM 351 in my garage and the ballast resistor came in at 1.8 ohm (loose terminal) and the coil was 1.7 kind of as expected. A stock 88 coil I measured over the summer was 1.6. I was feeling like KenO for a moment.
I was far too lazy to uncover my 88 and check it, and was supposed to ski tonight behind a few more late 80s CCs but the rain isn't going to allow it. I can't think of anyone here with a late 90s carb boat at the moment. |
TallTex
Groupie Joined: August-27-2012 Location: Austin Status: Offline Points: 41 |
Hi, thank you. OEM. I think I learned it does not have one. Likes full 12 volts and a low resistance coil. PCM Prestolite breakerless induction distributor is on a 99 SNOB, 5.8
Found a great test manual/procedure by Indmar for same distributor. I am following those steps for now. Thanks again. |
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1115 |
What year boat/motor/ignition system are you asking about? Also, is it stock or modified?
TallTex
Looking for resistance specs for pre-coil ballast resistor;
same for the coil Thank you if you know these or can point me to a chart/table in on of the online manuals |
