  New Posts New Posts RSS Feed - Sealant
Sealant
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Sealant
    Posted: December-12-2016 at 11:49am
Life boat caulk is pretty good too.
Tim,
I'm sure you meant to say Life-Calk?
I agree that the Life-Calk isn't bad but it being a polysulfide, I feel it's harder to work with. It's messier and harder to clean off plus I don't feel it's adhesion is very good. Also, a primer must be used on certain materials.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2016 at 11:18am
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2016 at 10:02am
Yep, 3M 4200 - any marine supply should have it.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2016 at 12:21am
Originally posted by Hollywood Hollywood wrote:
3M 4200
Agree on the 4200! NO SILICONE!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2016 at 11:24pm
3M 4200
trice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trice Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2016 at 9:55pm
What is the best sealant to use when mounting replacement pitot clam shells, pitot pickups, platform brackets and exhaust flanges? If my platform brackets where never removed and resealed, It appears that the CC factory used a clear rubbery sealant about 1/16" thick. Can you purchase pre-cut gaskets for these items or items like the through hull bilge port on the forward starboard side, the anchor light mount, the bow nav light, or the fuel tank vent port on the upper right stern? Thank you!
87 SN
