shaft collar |
The Dude
Platinum Member Joined: October-19-2004 Location: Houston Status: Offline Points: 1334 |
Posted: March-19-2017 at 6:38pm |
I sure love this site...I reference it all the time and should post more often.
New fuel sender, repacked rudder stuffing, shaft alignment, repacked shaft seal, general clean up the bilge (pretty clean anyway). Feels so good to get it all done. Excited to get on the water this week and see how dry the bilge is. Thanks everyone. |
Mullet Free since 93
95 Sport |
swilliams
Senior Member Joined: June-26-2016 Location: Cincinnati,Ohio Status: Offline Points: 236 |
Duane in Indy
type this into search line when you are on ebay
282307507033 edit or: 1" Inch Stainless Steel Double Split Shaft Collar - 2SSC-100 |
1978 Mustang (modified) |
Here's the direct link Doesn't work for me ether! |
swilliams
Thanks Duane,I couldn't post the link. I'll try typing it in.
Duane in Indy
This was posted above and earlier Just got one of these off of e-bay. It is spit so you can take it on or off without removing the coupling. Also the split type will not mark the shaft. All S/S http://i.ebayimg.com/images/g/LwwAAOSw6n5XtkIw/s-l1600.jpg |
swilliams
Can you guys be a little more specific about the 2 piece collar(part number, etc.)? Looking to do that for mine. Didn't mean to hi-jack this! Thanks
Duane in Indy
I suggest not reinstalling it. Order the 2 piece type and install it when it arrives. Took 2 days for me to get mine. Just my $.02 |
The Dude
got the collar loose
95 Sport |
Duane in Indy
Bout the same, $12.98 shipped BTW, My new PSS seal is arriving today, will install both |
Duane, not sure what the eBay price is but I grabbed several of the split collar stainless ones from amazon for $14 (free shipping). Cheap insurance.
David,
If you can't get it loose, you may need to cut the collar. I would use a cut off wheel in a die grinder (Dremmel) and cut close to the shaft. Then driving a cold chisel in the slot should open up the ID enough to free the collar. |
Duane in Indy
The Dude
dang salt water.
OK. I'll "work" with it tomorrow. I watched your most excellent vid on prop alignment yesterday Pete. I've done it several times, but it's time again with everything out. It started with new fuel sender. Then rudder packing, now shaft packing and alignment. |
95 Sport |
David,
FYI, that collar is the safety collar. If the prop shaft breaks say at the trans, it prevents the shaft from moving aft. A shaft breaking at the trans is one of the problems caused by poor engine to shaft alignment. |
OldSchoolBlue84
Yes sir, should slide, may have to work with it.
Kostas
1984 Ski Nautique 2001 |
The Dude
does this collar with the set screws sticking out move? I can't get the nut back far enough to be able to replace packing.
95 Sport |
