Disconnect Dummy Alarm |
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1115 |
Posted: July-11-2017 at 7:04pm |
He has the Protec system. Different than yours. |
Chris, The + source for the ignition, gauges, nav lights and most accessories is from the dash feed. |
Hawktique
Senior Member Joined: June-27-2009 Location: Iowa Status: Offline Points: 456 |
All jokes aside, I had the same issues. Inconsistent oil pressure gauge, alarms going off etc. cleaned gauge terminals, eliminated daisy chains with the use of terminal blocks, adjusted the module, and installed larger (matched) power and ground cables.
Or, you can just unplug the little black box and be on your way, without warning lights or tone. (Not advised) |
"A Veteran is someone who at one point in his life, wrote a blank check made payable to: 'The United States of America,' for an amount of 'up to, and including his life." Semper Fi
SNobsessed
Don't some of the electrons find there way thru the ignition wire & gauge wires? So possibly it can be a gage lighter?
Hawktique
I thought I recalled on my SN that the original power wire was twice the size of the ground. I rewired the entire thing with my dual battery system. The cranking battery only connected to the ignition/engine, while the isolated deep cycle battery ran all the accessories (lights, stereo,bilge pump,blower).
Pete is correct in the fact that Power and ground wires carry the same little electrons through your system. Often seen is the problem of insufficient grounding, causing all your components to fight over that ground, and nothing being happy. |
Josh, As an electronics tech, you should know that those electrons need to come from somewhere so, it's not only the ground that needs up grading. Ryan, There are a couple great threads on power to dash up grades. Links are in the FAQ thread in the maintenance forum. The typical is heavier gauge wire (+ and -) to buss bars at the dash. Then elimination of daisy chains. |
Hawktique
Also, clean every connection behind the dash.
Hawktique
Above link takes you to info on the module. Older nautique are notorious for having insufficient ground to the instrument panel. Had a '90, with some of the same issues.
Hawktique
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Easy and effective |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2957 |
swanbomb
Newbie Joined: July-05-2017 Location: Madison, WI Status: Offline Points: 15 |
1993 Sport Nautique 5.8L 351W PCM
swanbomb
How do you disconnect this?
