  New Posts New Posts RSS Feed - Trailer Bearing Sources?
TrevorB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TrevorB Quote  Post ReplyReply Direct Link To This Post Topic: Trailer Bearing Sources?
    Posted: June-13-2018 at 2:11am
I bought Timken set 4 and set 17 from Rock Auto for around $5 a set. All say USA on them.
1995 SNOB GT-40
mark c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark c Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2018 at 2:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2018 at 4:00am
This listing shows you the BCA National A- Set number and the interchange to the Timken Set number.   Most are the same but not all so be careful.
Should help if you need to ID your bearings.
Parts Stores can get you the correct numbers if you give them the Set number or you can use the modern update and order them in.
NATIONAL       Timken Set #
BCA #
BCA -      A1     Timken     Set - 1
BCA -      A2     Timken     Set - 2
BCA -      A3     Timken     Set - 3
BCA -      A4     Timken     Set - 4
BCA -      A5     Timken     Set - 5
BCA -      A6     Timken     Set - 6
BCA -      A7     Timken     Set - 7
BCA -      A9     Timken     Set - 9
BCA -      A10     Timken     Set - 10
BCA -      A12     Timken     Set - 12
BCA -      A13     Timken     Set - 13
BCA -      A14     Timken     Set - 14
BCA -      A15     Timken     Set - 8
BCA -      A16     Timken     Set - 16
BCA -      A17     Timken     Set - 17
BCA -      A18     Timken     Set - 11
BCA -      A19     Timken     Set - 15
BCA -      A20     Timken     Set - 20
BCA -      A21     Timken     Set - 21
BCA -      A22     Timken     Set - 25
BCA -      A23     Timken     Set - 23
BCA -      A24     Timken     Set - 27
BCA -      A28     Timken     Set - 28
BCA -      A29     Timken     Set - 22
BCA -      517011     Timken     Set - 29
BCA -      A30     Timken     Set - 30
BCA -      A30     Timken     Set - 32
BCA -      A31     Timken     Set - 24
BCA -      A32     Timken     Set - 32
BCA -      A33     Timken     Set - 33
BCA -      A34     Timken     Set - 34
BCA -      A35     Timken     Set - 45
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2018 at 2:51am
I will try again to attach a picture that can be read for the bearing sizes.
davidg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2018 at 1:36am
Gary....I did go out to Farm & Fleet as well to see what they had. They had a good assortment of bearings on the shelf there, but, didn't have the ones I needed.
I do like Farm & Fleet. I bought my Valvoline VR1 there this weekend for ~$4.50/qt. Plus, they have a plentiful supply of Fram Filters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2018 at 12:49am
Like it or not most are made overseas today but at least these guys provide a bearing you can trust.
Originally posted by davidg davidg wrote:
Shouse.....How much did you pay for the complete Timken set from Rockauto? Just curious vs. going through etrailer for Chinese bearings.
Last box of Timkins I saw a few years ago were made in China.
Post Options Post Options   Thanks (1) Thanks(1)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2018 at 12:07am
MrMcD.....that is very interesting and good information. I did not know this about bearings. That takes some of the mystery out of them buggers. I walked into Autozone and gave them numbers right from the bearings. They got the small outer bearings figured out pretty easily. For the much larger inner bearings, they had nothing. I went there primarily for grins and giggles just to see what they would say. O'Reilly's actually figured it right out. Just no stock. The local trailer place had them for 2x what etrailers wanted.
Shouse.....How much did you pay for the complete Timken set from Rockauto? Just curious vs. going through etrailer for Chinese bearings. Rock always has pretty good prices.
shouse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shouse Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2018 at 12:00am
Just bought Timken bearings for my Dorsey trailer at Rockauto.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2018 at 9:54pm
There is no magic in bearing identification.   Take them out and clean them.
The SAE has standard part numbers assigned to the bearing sizes.
You will need the number off both the cone and the cup. ( rollers and race )
Take these numbers to any parts store and they can sell you the correct bearing part.
The seals are a little harder but if you know the inner bearing race part the seal can be identified from the inner bearing size normally. The outer bearing is the smaller bearing, inner is the larger.
Popular bearings have set numbers assigned to them, a Set has both the inner and outer in one box. They are cheaper to buy if you know the set number.
The photo is hard to read, sorry but the information shows the Bearing part numbers and the National/BCA Part number or Set number for the bearings.
Note: Timken set numbers are almost all the very same but some like the A13 and A17 BCA numbers are not the same in Timken and a lot of boat trailers use the set A13 on the inner bearing.
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2018 at 7:53pm
TRBenj is the trailer guru (boat hull, parts and about anything else CC). Confident he will steer you straight.
        1978 Mustang (modified)
tbeard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbeard Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2018 at 7:43pm
Trying to identify the wheel bearings on my 89 Barefoot Nautique single axle trailer. 6 Lug wheels. I think the trailer is a 4DV. Thanks.....Tom
Thanks.......Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2018 at 12:28am
#4 with 5200lb hardware (6-lug).
The 3dv never came under anything larger than a sw18, and predated the swap to larger running gear (it used 3500lb 5-lug).
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2018 at 11:33pm
I "thought" I had a #3 DV trailer. Maybe it's a # 4, IDK. Anyway, here are the bearings for my trailer.
Kit # BK3-310.....
Includes
Outer Bearing LM67048
Inner Bearing 25580
Seal   GS-2125DL
Seal I.D.   2.125"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2018 at 11:08pm
+1 for www.etrailer.com
OldSchoolBlue84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolBlue84 Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2018 at 8:35pm
Spindle = #84 (1-3/8" inner, 1-1/16" outer)
Inner Bearing = L68149
Inner Race = L44610
Inner Seal = 10-19
Outer Bearing = L44649
Outer Race = L68111
I just installed, purchased through e-trailer, looks to be good quality.
#84 Spindle Bearing Set:
https://www.etrailer.com/Trailer-Bearings-Races-Seals-Caps/TruRyde/BK2-100.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2018 at 6:42pm
Thanks Tim! That is good feedback. I just bought the kit from them. With shipping, it was ~$50 for both sets which include bearings, races, seals, and cotter pins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2018 at 6:27pm
Have done lots of business with etrailer. They carry all the big brands (dexter, etc).
I have not had issues with the China stamped bearings either. The only set I’ve replaced and inspected still looked great after nearly 10yrs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2018 at 6:20pm
Thanks for the responses guys! I am very familiar with F/F, and also Adam's Enterprises. I will see what their prices/availability are.
Anybody ever buy bearings through etrailer? Their prices seem VERY good. Just wondering about quality!?
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2018 at 1:16pm
Dave,
Go to RA Adams on rte 120 in McHenry. They'll have everything you need. Take off a hub and bring it to them to have it all spec'd. They'll sell all components..
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2018 at 1:12pm
Dave Farm and Fleet had Timken about 2 years ago. Bet they still do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2018 at 12:57pm
When Buying bearings I try to stay with one of the name brands. Timken, SKF, National/BCA., NTN, or Hyatt. These are known to put out Original equipment quality bearings.
Some of the stuff imported today has very high tolerances, ( loose bearings ), they are low priced but you get what you pay for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2018 at 12:52pm
Where you guys buying your bearings these days? Autozone, Amazon, Ebay?
I am digging into the bearings now, and they look serviceable, but a little pitted. I may just replace them for peace of mind.
Does anybody happen to have the bearing #'s for a number 3 DV trailer handy? There are numbers on the current bearings.
- The large inner bearing looks to be MGM Radax K25580.
- The small outer bearing looks to be UTI K-LM67048.
Are there cross references to NTN or Timken bearings? Never heard of these.
