Distributor replace doesn't work |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Posted: June-27-2018 at 12:23pm |
Well, not quite otherwise you would have had a running engine after the install Did you get instructions with the distributor? |
bb12
Senior Member Joined: March-24-2009 Location: Kansas, USA Status: Offline Points: 355 |
Glad you got it figured out.
1989 Ski Nautique 2001
dougs_boat
Newbie Joined: May-19-2011 Location: Barrie Status: Offline Points: 10 |
Vince is a great guy. I had everything connected and configured correctly. I removed/bypassed the ballast resistor and the boat fired up no problem. Coil runs a bit hot, but should be fine.
Problem solved |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2957 |
Give Vince at Skidim a call. He is very knowledgeable and can help you troubleshoot your distributor issue.
JQ |
dougs_boat
Hi Everyone
I have a 1999 air tique 5.8 351W engine. After a long time trouble shooting an intermittent idle problem I think I found the problem, A bad bearing in the distributor shaft, it has a fair bit of play. I ordered and installed a new one from SKIDIM and I cant get the engine to fire at all. Anyone have any luck with these replacement distributors(sierra 18-5489-2)? I removed the distributor from the block and left all connections intact then I connected a spark plug to the output of the coil and it was sparking as I spun the distributor manually(I could hear them snapping and kind of see it on a sunny day). Spark plugs don't seem to be getting any spark. I put my old distributor back in to verify I am doing it correctly and after about 10 min it fired up no problem. Any advice is really welcome. Doug at the cottage |
