  New Posts New Posts RSS Feed - help identify parts please
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Topic: help identify parts please
    Posted: July-24-2018 at 9:45pm
OOPS sorry thought you meant valve covers but I see you mean the anti-syphon valve assuming the one with the braided fuel line, looks like it could be this
https://www.skidim.com/ELBOW-3_8-INV-FLARE-X-1_4-NPT/productinfo/R024017/
The straight one I would think is your vent and would just be a barb fitting for 5/8 vent tubing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2018 at 5:34pm
Filter you remove by turning counter clockwise it has an replaceable element inside, don’t damage the housing, you can still get them but not easy. You can use a Fram CG 20 or whatever brand you like that cross references. Make sure there is a new gasket in the box when you purchase it. GF 157 in AC filters
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2018 at 4:19pm
Valve covers are after market painted blue instead of original black, I have a set I’d sell if anyone is interested.
Coil is either resisted or not can check how it’s wired through the ballast resistor or use a meter.
Can’t help ya on the filter.
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2018 at 3:51pm
74 351 T-E.
Starts/runs well, gets a bit boggy maybe 45 minutes in, but never dies. Hasn't had much use, been running out the old gas, visually tank looks clean, but sure it's due for fuel filter, might as well ask about other potential culprits while here:
Can anyone identify below fuel filter, coil and valve and advise a source, and replacement process? (or any other ideas..)
Thanks
1974 Southwind 18
1975 Century Mark II
