Carb intall |
BaccoBouncer
Senior Member Joined: April-25-2016 Location: Essex MA Status: Offline Points: 285 |
Posted: August-03-2018 at 8:18pm |
How should I deal with this throttle cable placement difference between the EFI and the carb? Is there a standard bracket that will relocate it to the correct position?
'97 21' Sport Nautique
BaccoBouncer
Thoughts on loctite for the adapter plate no washer bolts or is it fine with the correct torque
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2957 |
I used a PCM gasket on each mating surface: between intake and spacer and then between spacer and carb. No vacuum leaks after 3 years...
I got torque specs from the Holley website for carb to intake mounting. You certainly can over-tighten. I used no thread locker nor lock washers. If you feel strongly about it, you could use a stainless steel nut with nylon insert. JQ |
BaccoBouncer
I am in the process of swapping my EFI to a holley carb setup. I haven't done this before and just want to make sure I do the details correct. In this pic you can see how I am assembling it. My questions.
Do I only do a paper gasket from carb to adapter plate? i.e. the black rubber spacer/vib isolator doesn't need a gasket on either side? The allen key bolts in the adapter plate don't have a loc washer? should I loctite them? Only a lock washer on the carb bolts? Torques? Any other tips? One additional question. The original steel intake manifold had a sheetmetal plate bolted to the underside. The new aluminum one does not. Need that plate? What is it? Thanks, Adam |
