  New Posts New Posts RSS Feed - Barracuda Dashboard Switches
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Topic: Barracuda Dashboard Switches
    Posted: June-28-2012 at 6:16pm
If it did have one they seem to have put them on the port side behind the rear seat between the tank and side of the boat.
It's also nice that over the years everyone reisted the urge to replace that vintage steering wheel
frydaddy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frydaddy Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2012 at 5:52pm
I love this forum. Thanks very much for the info. I was wandering what the relay was for. I am starting from scratch with the wiring and I had no idea there was a relay on the horn. I should have taken a picture of the wiring behind the dash. It looked like a Tasmanian devil got stuck behind the dash and ripped everything up. The boat is pretty original and I see no evidence of a bilge blower. I was told it is a 1968 Barracuda. Would a 1968 Barracuda not have a blower?
Frydaddy
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2012 at 8:38am
Chris,
I can take an educated guess on the push-pulls. You should have a 3 position for the nav lights. The other 2 should be 2 position and be for the bilge pump and blower. If the boat didn't have a blower, then that switch would turn the gauge lights on and off.
Did you look into the problem with the horn? Typically due to the high amp load that the switch in the wheel can't handle, there would be a relay. Is there one in the circuit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote frydaddy Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2012 at 9:06pm
I think this post has been solved, but here is a picture of my 1968 Barracuda dash. I am in the process of rewiring everything behind the dash. There are three push-pull switches. What do they control and what order? I am trying to get her back to original. Also, do you like the horn button? That was the fix when the horn switch broke in the steering wheel.
Frydaddy
Barracuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2006 at 11:23am
tleed- I just checked Overtons- they have the 2 position push/ pull switches for 9.99.
http://www.overtons.com/modperl/overtons/detail/pdetail2.cgi?r=detail_view&item_num=71694&fcat=2K8
tleed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tleed Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2006 at 12:38pm
Yeah, strangely enough, my P.O. didn't replace one of the switches, so I have one of the push/pull switches. Before all these posts I just figured it was a different kind of switch for a different purpose. Not so!
So now I'm on the lookout for the push/pull switches, which Midwest CC tells me they can obtain. I need four to get all of them back to original.
And thanks Brad. I have some work to do to get my boat looking as good as yours!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2006 at 11:43am
Here are a couple photos of the '65 dashboard switches:
Let me know if the photos are too grainy in quality..had to resize them to 20% of original size to upload them here. I can email them in full size if you'd like.
-Brad
The Lake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Lake Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2006 at 9:33am
Thomas,
My 69 Nautique has push pull chrome switches, pretty sure the dash is oriignal.
Chuck
Walk on Water
www.coldwater.me
69 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2006 at 8:33am
Hi- I don't have the Barracuda anymore, but I remember it did have pull out/ push in style of switches. The were for the lights and blower. I'll see if I can dig up some photos which show close ups of the dash and switches.
-Brad
Post Options Post Options   Thanks (0) Thanks(0)   Quote tleed Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2006 at 11:22pm
Mystery solved!
Discovered today right there on the shelf of my local Advance Auto: the exact same chrome rectangular-handled switch that I have on my dashboard. Looks like my previous owner cleaned out his Advance Auto to re-do the dash. And when I looked more closely at the back of my switches, I discovered a spliced-in section he added to connect the new switch.
So I bet Brad is right. Now I'm really wondering what kind of switch CCxHYPERLITEx has.
Thomas
CCxHYPERLITEx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCxHYPERLITEx Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2006 at 2:27pm
hye man ill just send it to you in a envolope itll be fine no charge but it might tkae a little while for me to go get it but ill try to get it asap.no longer than two weeks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tleed Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2006 at 1:51pm
77stang: good observation. Doesn't look factory to me, either. Radio Shack has "automotive" plastic paddle toggle switches for about $3 apiece. Wonder how much trouble I would get into using them. Are they "weatherproof"?
Unless I can get two to match, I think I'm going to have to replace all 4. Don't like the mongrel look.
Still looking for someone to tell me what their boat (hopefully another Barracuda) has on it's dash for the lights, bilge, blower.
Thomas
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2006 at 1:42pm
No lucking finding that swith on-line. You might consider just replacing all the switches with a marine plastic paddle toggle switch. The switches are failing inexpensive...under $3.00 each, I think. You even get name plates that fit under the bezel of the switch.
77stang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2006 at 1:40pm
the fact that the toggles on/off plate extends into the dash's "Starting Engine" letters makes me wonder if the toggles are orginal to begin with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tleed Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2006 at 1:32pm
Chrome like my pic above? If so, I'll take it.
Of course that would call into question Brad's advice to me that my switches aren't factory. Can anybody settle that question?
And Will, I want your switch. Tell me how to get it: $$, address, postage, etc.
You can email me that info at tleed@naxs dot net.
Thanks,
Thomas
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCxHYPERLITEx Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2006 at 1:15pm
toggle
Post Options Post Options   Thanks (0) Thanks(0)   Quote tleed Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2006 at 1:13pm
What is it, and where is it? Is it this kind of toggle switch, or is it a push-pull switch?
I've looked at various boats online, but can't find one with a close-up of the dashboard.
Thomas
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCxHYPERLITEx Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2006 at 12:36pm
i got one u can have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tleed Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2006 at 11:00am
Brad at Mid-west Correct Craft tells me the switch above isn't factory. He said it's been changed, and that it should have a push-pull on-off switch.
Is that why nobody's telling me they have another switch like this one? Anybody have pics of their original switches to post?
Thomas
Post Options Post Options   Thanks (0) Thanks(0)   Quote tleed Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2006 at 11:05pm
Ok, here's a pic of the switch. This one isn't the broken one, but it's just like it. I need two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2006 at 10:35am
Can you post a picture or email one to me?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tleed Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2006 at 1:30am
My 1969 Barracuda has various electrical issues, one of which is a couple of broken dashboard switches. Anybody know where to get these?
They're chrome rectangular flip on-off switches with a delicate little round rod that goes into the switch. I guess if the switch hangs, it's easy to bend the bar and snap it right off. At any rate, my light switch and one other switch are both broken off.
Seems to me this was a fairly common '60's electrical switch. But where to look?
Or anybody have 2-3 to spare?
Thomas
