water pump |
CCxHYPERLITEx ![]() Senior Member ![]() Joined: August-08-2006 Location: United States Status: Offline Points: 122 |
![]() ![]() ![]() ![]() ![]() Posted: August-10-2006 at 3:36pm |
he dont know whats goin on....i do all the work on most everything.car,SUV,truck.....
-will-
My 84 nautique |
Nautique2001 ![]() Grand Poobah ![]() ![]() Joined: June-14-2004 Location: Massachusetts Status: Offline Points: 2832 |
What's your Dad's thoughs on this repair?
Ken |
David F ![]() Platinum Member ![]() Joined: June-11-2004 Location: United States Status: Offline Points: 1770 |
I think he is taking about the inlet hose to the RWP nipple. Sometimes, the inlet hose is larger than the RWP nipple by 1/4" or so. If this is the case, most people use clear vinyl hose as a spacer which effectively enlarges the RWP nipple to fit the inlet hose ID.
79nautique ![]() Grand Poobah ![]() ![]() Joined: January-27-2004 Location: United States Status: Offline Points: 7872 |
there is suppose to be an o-ring that seals the unit not form-a-gasket. You should pay attention to things when you take them apart.
no i got a little on my finger and put a nice bead around the whole seal
-will-
My 84 nautique |
GottaSki ![]() Grand Poobah ![]() Joined: April-21-2005 Location: NE CT Status: Online Points: 3341 |
Depends, did you take it apart and do it right or just glob it on the outside like a hack?
River Rat to Mole |
hey guys,
got me another question.my 89 ski nautiques impeller seal with the hose was bad.it was snaggin air causin the impeller to not function right therefore the temp gauge would peg cause the block wasnt gettin any water.so we put a bead of silicon round it and it did the job rite nice.so what im askin is should i keep tryin my look w/ this silicon seal or is there somethin else i can do? |
-will-
My 84 nautique |
