351 winsor water temperature |
Posted: August-19-2018 at 4:44pm |
tmcboat
Newbie Joined: April-22-2018 Location: Georgia Status: Offline Points: 28 |
HI All,
I have a volvo penta stern drive and a holly 4 bl carb so 160 degrees is ok |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2106 |
is this a stern drive or a true inboard? Ford EFI like to run at 160*-170* carby motors 140*-160*
bb12
Senior Member Joined: March-24-2009 Location: Kansas, USA Status: Offline Points: 355 |
Carbed 143
EFI 160 |
1989 Ski Nautique 2001
tmcboat
Hi All,
I have a 160 degree thermostat in my 351 winsor -- it will sometimes go to 170 degrees max should i install a 180 thermostat- I read that the 351 winsor runs best at 190 but i think in a marine application thats too close to 200 degrees which doesn't give you much time to react in an overheat situation ex. broken belt, raw water pump or main engine water pump failure or blocked stern drive raw water intake? one person said you get about 3% more horse power if the temp is closer to the 190 degree range-?anyone know if this is true? your thoughts and suggestions please tmcboat |
