  New Posts New Posts RSS Feed - Can anyone here decode my '68 Mustang HIN?
zwoobah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zwoobah Quote  Post ReplyReply Direct Link To This Post Topic: Can anyone here decode my '68 Mustang HIN?
    Posted: November-16-2018 at 7:54pm
Don't have any overall engine photos. The risers fit under the stock doghouse with some cuts to the inside doghouse fiberglass (no modifications visible from outside). The boat is shrink wrapped for the winter, so will have to wait until spring for more photos.
1968 Mustang 16 - 351W powered
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2018 at 7:46pm
Chris,
Thanks for the picture. Northeast sounds like an engine rebuilder and not the marinizer. Do you have a picture of the engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote zwoobah Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2018 at 7:39pm
Northeast Ford Engines appears to be the distributor or marinizer. They are out of business. It's reverse rotation, right hand prop on the boat (351R = reverse, I assume)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2018 at 7:33pm
Originally posted by zwoobah zwoobah wrote:
It was replaced with the 351W that's in the boat now.
Chris,
Who's the marinizer of the 351 and what rotation is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote zwoobah Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2018 at 6:38pm
Thanks Pete. I believe I am the third owner of this boat.
Previous owner was told that the original owner forgot to winterize it at some point in the 70s, and the original 289 cracked. It was replaced with the 351W that's in the boat now.
Would be interesting to confirm whatever info CC has on file - I'll try emailing them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2018 at 6:34pm
Cris,
In a 68 Mustang, the common engine would have been a Ford/Interceptor 289.
Here's the brochure if you haven't found it yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2018 at 6:29pm
Can I email CC?
Chris,
Some have tried and gotten results but others haven't. I sometimes feel CC doesn't care about us with older boats!
Post Options Post Options   Thanks (1) Thanks(1)   Quote zwoobah Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2018 at 5:52pm
Thanks Pete. Does anyone have access to the older build sheets for these boats? Can I email CC?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2018 at 5:50pm
Chris,
There isn't any decoding that can be done since that is not a HIN. It's simply a serial number that CC used before the early 70's when HIN's were started.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zwoobah Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2018 at 5:26pm
Purchased a '68 Mustang this past fall. Would be interested to know the original motor, color, or any other info available. HIN is M 2296. Thanks!
