Zero Off not working |
tryathlete ![]() Platinum Member ![]() ![]() Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1798 |
![]() ![]() ![]() ![]() ![]() Posted: June-09-2019 at 7:04pm |
Call Jody Seal at Florida Inboards or PM him on this site if The Perfect Pass folks don’t come through. He’s a wizard.
http://www.floridainboards.com/ |
dstop ![]() Groupie ![]() ![]() Joined: March-10-2009 Location: Canada Status: Offline Points: 70 |
I cant figure out where the fuse or breaker would be for the Zero off unit
any idea ? |
Yeah I get it. If you want to fix it yourself there are a whole host of manuals on their site too. I have no idea how the whole signal processing works but I suspect since Zero off only works with ECM based throttles which I assume work off of the CAN bus on some sort of J-1939 protocol or newer. Maybe check power connections, fuses and breakers just to do the basics. It’s probably something simple! |
Yup. Thats the plan .
Only I was hoping to try to figure it out over the weekend. Thanks |
Email - Technical Assistance: support@zerogps.com
Give these guys a call tomorrow
https://www.zerogps.com/ |
Hi All
I have a Ski Nautique 2010 with a Zero Off unit. I just put the boat in the water for the first time this season and my Zero Off wasn’t working, At First I thought it was the connector, because some times in the past the connecter would come loose from the head unit. When I checked it the today the Head unit was actually disconnected from the connector, however when I reconnected it, it still didn’t start up. I am unable to get it to start up. The strange thing is that last fall it was working fine before I put it away for the winter. I had a look at the wiring and all seems ok, I have no way to test the head unit, to see if it works and maybe its just a wore connection. Any thoughts Please let me know ASAP, summers short here in Canada Thanks |
