  New Posts New Posts RSS Feed - cutlass bearing supplier
hotrod5337 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrod5337 Quote  Post ReplyReply Direct Link To This Post Topic: cutlass bearing supplier
    Posted: July-10-2019 at 6:06pm
awesome news! thought I was going to be looking for a new strut.
thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2019 at 5:53pm
Damon,
Struts are notorious for sloppy machining so don't worry you did not purchase the wrong cutlass. It only takes one thousand's of an inch to go from a press to a slip fit. I have run into the slip fit issue and yes the set screws will hold the cutlass in but I've also used a small amount of blue Locktite. (or Todd's favorite "koctite")
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrod5337 Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2019 at 5:45pm
i.d. of the strut is measuring 1.245 but the new bearing o.d. is measuring the same. actually measuring the old bearing o.d. at the part that wasnt cut into with removing is measuring just under 1.25 as well. guy from deep blue is telling me to use epoxy. I was going to get you guys opinion as everything I've read on here has been to install with threaded rod after freezing the bearing
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrod5337 Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2019 at 5:34pm
new bearing from deep blue came in today but it isn't a press fit. its tight but I can slide it in by hand?   is the set screws enuf to hold in place? I had to cut the old one out. the bearing I ordered from deep blue was the 'back' bearing. 1.25od for 1" shaft 4" long. did I order wrong one?
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrod5337 Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2019 at 11:31pm
it's still nice n tight. socket pressed it off. shaft and coupling surface looks good. dont remember any issues with vibration or noise but I will measure shaft runout since one of the prop blades has a nice nick in it. hopefully it's good. if not I may bite the bullet and do the A.R.E. I dont ever plan on selling so I can see that kit being money well spent as far as future maintenance goes
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2019 at 10:50pm
Originally posted by hotrod5337 hotrod5337 wrote:
   I definitely dont want to take the coupling off more times than i have too.
Damon,
Fill us in on the R&R on the coupling. Is it still the heat shrink interference fit between the coupling and shaft? If it slips on without heat, then the fit has fretted due to misalignment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrod5337 Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2019 at 10:24pm
I think I'll take your advice and replace. I definitely dont want to take the coupling off more times than i have too. I'm just concerned about possible drivetrain realignment after the new bearing is installed. this boat is nickel and diming me to death
thank you for the response. I have been on deep blues web site. I will call them in the morning. maybe they will be open
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2019 at 9:13pm
Damon,
You should be getting less movement. If you can see it move, then it's too much however I'm sure you can run it for more hours.
I use Deep Blue for cutlass bearings
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrod5337 Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2019 at 8:39pm
actually after reading some other post I'm wondering now if replacement is necessary. I'm certain it's never been replaced and boat has 1400 hours. movement is very minimal. I'd say 1/16 either way. moving it with coupling detached from tranny.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrod5337 Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2019 at 6:20pm
noticed last night before I re installed prop shaft coupling that Im needing to replace cutlass bearing on 74 mustang. been using skidim for parts but they are closed til Monday. hoping to find somewhere opened tomorrow that could ship Saturday so I can get this boat together.   my work has me way behind with getting boat ready and I'd like to do so before I go back to work next week. prob a shot in dark but figured I'd ask
thanks
