  New Posts New Posts RSS Feed - Bad Electric Ignitor-prestolite distributor
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Topic: Bad Electric Ignitor-prestolite distributor
    Posted: July-19-2019 at 11:56am
Originally posted by Brett Brett wrote:
Wait-that makes me a butter knife??
Ken is at least in the butter knife drawer;
There is
1) Good
2) Butter
3) Best (Sharpest knife in the drawer).
Ken obviously fell from 3 to 2 by mistake. Maybe there are too many sharp knives in the CCF drawer. Ken: your willingness to delve deeply and provide specifics for those in need is astounding and truly commendable. It’s help like you provide that brought me to this forum when I owned a Water-logged, under-powered Supra.
Brett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brett Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2019 at 11:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2019 at 9:45am
Aw shucks JQ
I usually hang out in the butter knife section, I'm safer there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2019 at 2:32am
Dang- you are good!!!
Just so so
There is also a cheaper version from Pertronix part number 1589. It's the earlier original ignitor and it's about 115 dollars.
If you leave your key on with the engine off accidentally, you can burn out the module.
With the 91589, some magical internal circuitry senses that power is on and the distributor isn't turning and kills power to the module to prevent burning it up.
Cummon Ken, you're way better than just "so so". You rate a strong "fair-to-middling" at the very least.
[All jokes aside, KENO is one of the sharpest knives in the CCFan drawer]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brett Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2019 at 4:58pm
Calling you so-so is like calling the great wall of China a decent fence!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2019 at 4:23pm
Just so so
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brett Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2019 at 4:13pm
I was going to but the 1582...thanks for the info.
Brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brett Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2019 at 4:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2019 at 4:03pm
Somebody replaced your whole distributor at some point because that distributor wasn't used till 1987 with points and around 93 you could get it with that module or buy the kit for the earlier points version..
It's a Prestolite screw down cap distributor with one of the Prestolite electronic modules.
Those modules are kinda hard (pretty much impossible) to find new these days. It was discontinued a long time ago
For that particular distributor with the 8 legged reluctor wheel in the middle, Pertronix makes a kit part number 91589.
If you come across a Pertronix 1582 kit for the screw down cap, it won't fit because of that 8 legged reluctor wheel
It's around 150 bucks at Jegs, Summit etc.
Because of that wheel, the Pertronix is probably the only kit you'll find
I have to go and take cover now, cause the throngs of Pertronix haters are gonna throwing lightning bolts at me
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brett Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2019 at 3:35pm
I thought that was a possibility.
Brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brett Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2019 at 3:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2019 at 3:11pm
How about a picture of the distributor with the cap off showing the "ignitor" so people can know what you're dealing with.
40 years ago your boat came with points and somewhere along the way the electronic kit would have been installed.to replace the points
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brett Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2019 at 2:32pm
Quick question-
No spark that I believe I have traced down to the electric igniter being bad in the distributor.
Did a click test I found on you tube, no click. 120.00 bucks for a replacement, not bad...has anyone experienced this? if so, is it usually just a 40 year old part dying or a symptom of a bad distributor?
Appreciate all help.
Brett
