  New Posts New Posts RSS Feed - '82 CC Attwood trailer jack wheel
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Topic: '82 CC Attwood trailer jack wheel
    Posted: August-04-2019 at 1:47pm
I bought a 6" jack wheel from etrailer. ( F6811S00 for $17.00 ) The description references Fulton jack, the original CC unit is Attwood. It works perfectly. Drill out the original rivet, then enlarge the hole on one side to fit the replacement axle bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2019 at 9:03pm
Original steel wheel, center has broken out, doesn't roll. Appears to be held in with a riveted pin, which can be ground off and removed. Anyone find a suitable replacement wheel? Thx
