Raw water pump identification |
swilliams
Senior Member Joined: June-26-2016 Location: Cincinnati,Ohio Status: Offline Points: 236 |
Posted: July-30-2019 at 10:10pm |
I will look for the number on the seals I found. Plates could be very hard to find but a tool and die shop could probably fabricate them.
1976 Martinique,350 Omc. 1975 Glastron/Carlson CV16,115 Merc.
800wildcat
Senior Member Joined: July-05-2010 Location: Ripon, WI Status: Offline Points: 121 |
Found a bearing and impeller, but nothing else so far. Would be nice to find a seal although the old one does not yet leak and it would be really nice to find the steel plates.
swilliams
Omc. Rebuilt the one I have on the motor now. Seals, impeller and bearing can be found but a lot of cross referencing took place to find them. You will have to make your own gaskets. Best choice would be to invest in a crank mounted pump. I won’t rebuild another one for sure!
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Thanks(1)
800wildcat
Can anyone help identify this raw water pump and perhaps point towards where to get a rebuild kit for it? Or another pump? Has number 908920 cast into the backside, appears to be an OMC. Came off a '75 SkiTique with a SBC. It's mounted on the lower left side of the engine block when viewed from the front of the engine. Don't know boat's history past about the last 7 years other than the engine was replaced about 6-9 years ago so have no idea if pump is stock. Back plate has a fairly deep gouge and couldn't find key for impeller and metal bushing inside impeller rotates free of impeller, so need a few replacement parts.
