  New Posts New Posts RSS Feed - Need a mid 70's trailer
Jeff57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff57 Quote  Post ReplyReply Direct Link To This Post Topic: Need a mid 70's trailer
    Posted: January-30-2020 at 10:21pm
Really? That’s good news. Thanks!
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2020 at 10:17pm
I think the trailer remained the “same” until 85
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff57 Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2020 at 10:01pm
just found the hull change info in an earlier forum string - Looks like the 2001 hull came out in 1982. So an '83 trailer is probably too big for for 1981 and older boats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff57 Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2020 at 8:53pm
I think it will work. I'm not well versed enough on whether the hull changed much from '78 to '83. If not, I'd like your trailer. What are you asking for it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff57 Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2020 at 8:33pm
I think I saw your post and was considering. I had an '89 SN a couple of boats ago and I think you have the same trailer. Same design I want but I'm worried that it might be too big (wide) for the 70's hull. Could you send me dimensions? Key is the width of the carpeted rails at the transom and center.
83CCSN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83CCSN Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2020 at 8:24pm
It's not 70's but I have an original trailer from 1983
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff57 Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2020 at 8:21pm
I just started restoring a 1978 SN. Came with a trailer. I'm not a fan. Its not OEM. I would like to find an original trailer. Any sources? Any trailer builders make a copy of the original CC trailer?
