  New Posts New Posts RSS Feed - wood motor  mounts
wood motor mounts
93/70 ccpb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 93/70 ccpb Quote  Post ReplyReply Direct Link To This Post Topic: wood motor mounts
    Posted: May-01-2020 at 12:14am
hey dan if you need a different lengh shaft,i have about 4 of them you can try,just stop by.
what you dont want to hear from jbear and bill.you cant get in the boat till you get your minute,and they throw you back in water!
scuba129 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scuba129 Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 1:30pm
just watched the video
THANKs for all your advice
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 12:50pm
Here's a link to the video
BTW, I hope you have found the FAQ thread. Lots of great stuff in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 12:47pm
Dan,
Have you watched the alignment video? There's a link in the FAQ thread in the maintenance section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scuba129 Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 12:31pm
This comment was like a light bulb Turing on for me.
"The angle of the engine MUST MATCH the angle of the prop shaft. The shaft MUST BE parallel to the engine".
Got it
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 12:10pm
Moving the engine forward to dial strut/shaft/prop geometry isn’t proper either... engine belongs where it belongs and shaft length should be tuned accordingly.
Pete should be able to do the math and see how much prop to hull clearance is impacted by moving the prop back 1/2” (strut angle is 15°). Hint: it’s not much
Like Pete said I don’t think you’ve quite grasped the concept of proper alignment...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 12:04pm
Dan,
Yes, you can move the shaft forward but as you mentioned, it reduces the hull to prop clearance. It's a "toss up" as to what's better. Go say a 1/4" forward and see what happens.
The angle of the engine MUST MATCH the angle of the prop shaft. The shaft MUST BE parallel to the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scuba129 Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 11:58am
Thanks for all the info !!!
OK so I should move the prop to within 1/2 inch of the strut? correct.?
is so then this raises my prop shaft up a little bit and that helps close my 1/4 gap.
Can motor angle max out at 20 degrees if needed?
How close can prop come to hull of the boat ? I am at 1 inch now .
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 11:42am
1” from the strut to prop is on the excessive side. Likely set up that way from the factory but not ideal .
Dan,
Understand the 1" is not "ideal" per Tim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 11:16am
1” from the strut to prop is on the excessive side. Likely set up that way from the factory but not ideal if you are trying to dial it in and set it up properly. Minimizing clearance would be better if you can... just enough to get a puller on is fine. Aim for 3/8”-1/2”.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 11:08am
Originally posted by scuba129 scuba129 wrote:
Hi,
centered the the prop shaft in the shaft log. The prop (12x14) is set at about 1 inch from the end of the strut. This gives me about 1 inch clearance between the prop and the hull. Is this all correct so far? .
If the shaft in "happy" ( turns freely) then the shaft and strut alignment is good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 11:06am
Hi,
The motor sits at 15 degree angle BUT I need the trans to be about 1/4 lower
I considered cutting the stringer but that increases my motor angle .
Dan,
Alignment can be frustrating especially the first time when new or in your case after new stringers. Per your description sound like both ends of the engine need to go down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scuba129 Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2020 at 10:52am
Hi,
Yes I having an issue with alignment
I replaced all the stringers and made new wood front mounts to the exact size of the original mount .New mounts are made out of white oak .
I replace the strut bearing and centered the the prop shaft in the shaft log. The prop (12x14) is set at about 1 inch from the end of the strut. This gives me about 1 inch clearance between the prop and the hull. Is this all correct so far?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2020 at 2:33pm
Dan,
Are you having problems with alignment? Just wondering why you want to get away from the wood.
Keeping it all original .
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote scuba129 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2020 at 2:19pm
HI,
I want to replace the original wood motor mounts with upgraded adjustable mounts..
Any recommendations Please?
1965 mustang 289 interceptor
