351 Rebuild Manual |
JoeinNY ![]() Grand Poobah ![]() ![]() Joined: October-19-2005 Location: United States Status: Offline Points: 5698 |
![]() ![]() ![]() ![]() ![]() Posted: September-27-2006 at 8:36am |
The hayes manual is not a bad place to start, but I wouldn't trust it all the specifications in it for marine use. Make sure you follow the piston/ring suppliers advice on marine clearances, if your pistion supplier doesn't have or publish these recommended clearances for marine use then don't use those pistons for marine use.
jimbo ![]() Senior Member ![]() Joined: September-07-2004 Location: United States Status: Offline Points: 473 |
I bought the Haynes Ford Overhaul Manual a while back. It's pretty easy to follow and has a lot of photos. But I haven't used it to do a rebuild yet. Good luck.
Jake ![]() Groupie ![]() Joined: February-24-2004 Location: United States Status: Offline Points: 44 |
I'm starting to prep for a rebuild on my '79 Nautique.
Can anyone recommend a good manual for rebuilding my 351? Thanks in advance. Doug |
