Trailer Question |
![]() ![]() ![]() ![]() ![]() Posted: August-07-2020 at 2:26pm |
John,
You've been busy. Looking great!
MrMcD ![]() Grand Poobah ![]() ![]() Joined: January-28-2014 Location: Folsom, CA Status: Online Points: 3777 |
nice work
jterr ![]() Gold Member ![]() Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
Great to see CorrectCraftFan.com back up
![]() Few pics of almost finished trailer repair ![]() ![]() ![]() |
Thought I would post a few pics of trailer work.
Welded and painted, still have to run a brace to next bracket in front with some skids ![]() Redid Fender as boat had been hitting ![]() Tongue ![]() My thought of a tie down with a safety chain ![]() PO did this not sure what went there?? ![]() ![]() |
John,
There are other trailers that are a lot lower than the 6". You made a good choice. Still plenty of clearance at the prop. |
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3009 |
That’s about the same clearance my trailer has. I welded some steel rollers on the bottom cross member so that the prop cage didn’t simply drag on the ground when going over dips, gutters, etc.
JQ |
Went with the 6".
Thanks |
Trying to build the prop brace that some trailers had and don't have one to look at. See pic and asking should the bottom of brace be at the 6" or 8" from ground??
