  New Posts New Posts RSS Feed - New Prop
New Prop
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Topic: New Prop
    Posted: August-13-2020 at 5:05pm
Originally posted by GottaSki GottaSki wrote:
We are addressing Ralph, as he started this post inquiry
Acme 540
Yep 540 for the '86 2001 SN
I ran a 1442 3 blade on my '95 SN GT-40 and now running it on my 2000 Sport and it gets the job done nicely slalom, wake-boarding and surfing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2020 at 6:49am
Originally posted by slmskrs slmskrs wrote:
Originally posted by gun-driver gun-driver wrote:
ACME 540  3 blade... period
Why is it a better prop than a 4 blade (ACME 422)?  I like everything that my buddy's ACME 431 for his MC did; would love the same for my boat, but leery about what it would do to my wake vs the stock 4-blade.  If it will make it softer, I'd go for it.  My '96 had a 3-blade, and I tried a 4 blade twice at two different times and everyone thought the 3 blade was softer, so I stuck with it.  But the '97 and newer all have 4-blade.  I don't know that there is anyone that is going to let me try and buy a ACME540; if I don't like it, I get to return it for a refund.
Size and style of prop are more important than blade count. Often your choices are somewhat limited amongst all those criteria. Blade count will have less of an effect on proper rpm and resulting speed than the other design considerations. You are comparing prop models for 1:1 and 1.23:1 boats (varying by 3”+ pitch), they are apples and oranges. Would suggest a bit more learning before selecting one.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2020 at 4:47am
Acme 540
River Rat to Mole
slmskrs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slmskrs Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2020 at 2:00am
Gordon '97 Ski Nautique, GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2020 at 1:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote slmskrs Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 11:39pm
What he got was a somewhat stronger pull when pulling heavier skiers out of the water, and somewhat lower RPMs at 34.2 and 36mph than his 4-blade.  He did lose 1-2mph on WOT, but on a tournament ski boat (slalom only) that never goes over 36, top end speed is not much of a concern.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 7:29am
he hole shot was better (higher speed at specific RPMs on the low end)
I think 'hole shot' typically refers to the 'rate of change' RPM increase during take off, not the steady state RPM at low speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote slmskrs Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 1:49am
original prop was 4 blade, new prop 3 blade.
Post Options Post Options   Thanks (0) Thanks(0)   Quote slmskrs Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 1:48am
It didn't make a lot of sense to me either; I know Bryan from Valley Prop is a big proponent of 3 blade over 4 blade.  My buddy's MC had a 4 blade, and he got improved hole shot but lower RPMs on the higher end.  Speeds were recorded at various RPMs (using PP RPM mode) on the old prop, and when my buddy got the new prop from Bryan and did the same tests over again, the hole shot was better (higher speed at specific RPMs on the low end), and lower RPMs on the higher end (30-36mph range).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2020 at 4:56pm
Better hole-shot and lower RPMs are typically somewhat mutually exclusive.  For better hole-shot, most would look to a lower pitched prop — thus enabling the engine RPMs to climb faster into the “power band”.  The lower or shorter pitch would translate into higher engine RPMs at a constant speed.  Now, if your “base” prop was a non-CNC and poorly tuned or repaired, then you may be able to increase hole-shot amp RPMs concurrently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2020 at 4:33pm
One other thing.  My buddy wanted a better hole shot for big skiers, but wanted his overall RPM lower.  Bryan was able to get him a perfect prop.
How did he do it? CNC prop after he was running a hand worked? Typically a better hole shot is by lowering the pitch but, that increases the RPM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote slmskrs Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2020 at 3:57pm
Valley Propeller Service
Bryan  805.644.5055
Ventura, CA
New Prop Sales, Computer Repairs, Inboard, Outboard, Sterndrive
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2020 at 12:49pm
Delta Propellers has been a CCF site sponsor in the past
repifanio2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote repifanio2 Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2020 at 12:28pm
Thank you
RKE
Post Options Post Options   Thanks (0) Thanks(0)   Quote slmskrs Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2020 at 12:05pm
Bryan  805.644.5055
Ventura, CA
One of the members of our club (skis Big Dawg tourneys) recommended this place.  Several of our members have used him.  He is very knowledgeable and will work with you to find the best prop.  One of my ski buddies who has a MC called him.  Bryan had him provide speeds at certain RPMs, then recommended a 3-blade over his current 4-blade.  He tried it and it the wake was as good or better than the 4-blade, and the RPMs were just where they wanted them.
I believe it was an ACME prop.
He also uses CNC for repairs.
So far everyone has been happy with him.
Fabcon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabcon Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2020 at 12:02pm
Acme 540
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out)
Post Options Post Options   Thanks (0) Thanks(0)   Quote repifanio2 Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2020 at 9:28am
Need to replace my prop for 1986 2001 correct craft. Any suggestions on size and maybe company to buy from?
RKE
