  New Posts New Posts RSS Feed - PCM40 won't engage after seal change
windsurfnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote windsurfnut Quote  Post ReplyReply Direct Link To This Post Topic: PCM40 won't engage after seal change
    Posted: September-02-2020 at 8:37am
Yes, I do hate when I make a statement like that and find I didn't pay attention to a simple detail!
And the wine..we'll that's what started this all, all I wanted was a chill cruise and a glass of wine after doing the job on Sunday and some busy days at work.  In the end, I was able to still pull that off.
Thanks for the quick responses!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2020 at 11:33pm
Nice work, a WIN!  Should celebrate with COLD BEER, wine just does not cut it.😎
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2020 at 8:49pm
Originally posted by windsurfnut windsurfnut wrote:
Just changed my front main seal on my PCM40, and now the prob won't spin in either direction.  Just seems to be stuck in neutral.
Nothing seemed overly complicated when changing the seal, what could I have done incorrectly?
Don't you hate it when you make statements like that? Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote windsurfnut Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2020 at 8:38pm
LOL yes I certainly did!
Post Options Post Options   Thanks (0) Thanks(0)   Quote windsurfnut Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2020 at 8:37pm
Nevermind..  Figured it out, pump front plate arranged for the incorrect engine rotation.
All fixed.
Note the time..fixed, quick cruise and a glass of wine.  With no helpers..
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2020 at 7:06pm
Jeff,
You installed the pump on the front of the trans wrong for the rotation of your engine. The pump position is rotation specific.
Bingo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2020 at 6:50pm
Jeff,
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2020 at 6:45pm
See if the cable is hooked properly to the shift controller, then remove the cable and see if you can operate the shift control normally by hand, you should feel it hit the detents (spring loaded ball) that holds it in each position.  Forward, Neutral and Reverse.   I would start with the basics and the issue should show up.
I am guessing the trans cooler was hooked back up properly and fluid was replaced after install.
The splines on the tranny properly installed into the flex plate, Damper.   Just basics but something is off or you would be working fine already.   Hope you fix it quickly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote windsurfnut Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2020 at 6:23pm
