  New Posts New Posts RSS Feed - Need new Acme prop, recommendation?
halfnelly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote halfnelly Quote  Post ReplyReply Direct Link To This Post Topic: Need new Acme prop, recommendation?
    Posted: September-10-2020 at 10:57pm
*not the stock tach
Good eye, it was replaced about 6 or 7 years ago. Closest one I could get from NautiqueParts, I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2020 at 10:57pm
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote halfnelly Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2020 at 10:55pm
Nelly,  what HP engine sins a 422 to 5,600 rpm?  In what hull?  My 310HP in the 95 196 only turns around 5,000, maybe a touch more on a good day.
I used to spin 5,300 rpm when I ran the acme 224.  I liked that prop but had it repaired again and it is not the same.
94 Sport, 351 Pro Boss carb. The Sport rides a little less bow heavy than a Ski, probably worth a couple of MPH. My 422 has been repaired a handful of times, I'm sure that's not helping the RPMs stay down, either.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2020 at 9:17pm
Originally posted by Faceplant Faceplant wrote:
Curious. What do you mean when you say  - too much prop ?
The engine did not have good throttle response at wakeboard speeds 18-20 mph.
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2020 at 7:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2020 at 7:35pm
*not the stock tach
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2020 at 7:01pm
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2020 at 5:09pm
My '89 had the 240hp 351w.  I tried the 422 and as mentioned it was too much prop.  I went back to the OJ that came with it.  Don't remember exactly what it was but it worked better.
92 SN - Owned since 93
99 Pro Air
89 SN - Went to live on a lake in Texas
75 Donzi 16 - Sold in 93
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2020 at 4:18pm
I had ACME 1442 on my 1989 2001 & it was just right for us (wakeboarding with moderate ballast).
The 422 was just too much prop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote halfnelly Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2020 at 2:12pm
Originally posted by Netdewt Netdewt wrote:
I went for the 654. The 2068 is not repairable (not surprised).
So my spare is an old non-Acme that was lightly repaired by my uncle. It works but it’s rough.
Do you all keep nice spares?
What is your max RPM for a 351W? I stay under 4500, and that’s just short bursts for fun. Daily usual RPM is under 3000.
You'll get better performance if you let it spin a little, 5000 is safe. My 1600 hour 351 will turn my Acme 422 to 5400 and my 1868 to almost 5600. The 1868 is a bit too short, I try not to run WOT on the top end. It's a great low speed and holeshot prop, though.
You can also see in the photos how off the stock tach is compared to the PerfectPass.
422:
1868:
Netdewt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2020 at 1:17pm
1989 Ski Nautique 2001, 940 hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2020 at 4:41pm
4 vs 3 blade is always a fun discussion.  That being said...how many LARGE wake boats are sold with a 3-blade prop as stock configuration?  Go with the 4-blade.  If you really want low-end grunt and slower speed performance, consider the 1868.  Just watch the tach as you can over-rev by several hundred RPMs with a good engine and the 1868 (voice of experience).  Hole shot will be very strong...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2020 at 12:29pm
Originally posted by Jonny Quest Jonny Quest wrote:
654 is a good choice as it’s a “tweeter” in between the 422 and 1868.
Good call. I think Acme is recommending this also.
Is 4 blade going to benefit me? I don’t do ballasts. I’m hoping for better speed control in the 17-22mph range, but maybe that’s always an issue without Perfect Pass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 12:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-06-2020 at 8:29pm
I have the 422, it is a nice prop, tops out around 46 with the 310 HP Pro Boss.  Very strong out of the hole and quiet always.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Posted: September-06-2020 at 7:39pm
I have a 1989 Ski Nautique 351W. I currently have (had, we found some rocks) an Acme 2068 that was installed by the previous owner for max speed (I could almost get it to 50mph).
Can you recommend a prop for best performance at 15-25mph? We trick ski and wakeboard, not much slalom speed needed.
I’ve seen 422 and 1868 recommended. There are so many variables I don’t know how to choose. My understanding is this boat is the first year with the 1:1.23 trans, and so uses different props than other 2001s.
Anyone have a favorite?
