  New Posts New Posts RSS Feed - Winterizing...
Winterizing...
AAM196 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Topic: Winterizing...
    Posted: October-12-2020 at 6:16pm
Not really... I do spike it a bit on the 2nd or third use.. I recycle it after that and start fresh. That being said, It resides in a heated garage. Having a helper makes job pretty easy.
Having single exhaust also helps with the collection..
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2020 at 5:41pm
Originally posted by AAM196 AAM196 wrote:
and you can use the same batch for years...
Do you recheck concentration?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2020 at 2:30pm
Hummm... I always fog engines going into layup... regardless of the temp it will be held at unless you will be turning it over every week or so to get oil on cylinder walls walls etc.
If you have a way of collecting the antifreeze and collecting/recycling easy if you are on a trailer... I just use regular glycol antifreeze... has anti corrosion properties and mixes with water.  a pair of 5 gallon buckets and a lid and you can use the same batch for years... even storing in heated garage... peace of mind.  Just make sure you cap your bucket if you have animals around!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2020 at 6:17pm
Oppps, disregard. That's an additional drain and soap-inlet for the impeller come spring time. We're pouring in from the outlet of the RWP ;-) Easy-Peasy
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2020 at 5:06pm
For those pouring in the A/F from above the impeller, are you putting a 90 on this fitting, so you don't make a mess trying to use a funnel and hose on this side-facing opening?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2020 at 4:36pm
Gary,
Please note I'm late this year! Big smile I could hold off for several weeks but those below 40 degree days are getting rough on the hands.
You were just hoping that with all the global warming you'd get a bonus boating day LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2020 at 2:29pm
 I can't stress enough the importance of being able to probe the drain holes for anything that may plug them up. I just got done winterizing my 312 and both block drains and both manifold drains were plugged until I got the wire in them. The only drain that wasn't plugged was the one on the bottom of the RWP!
Gary,
2001SAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2001SAN Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2020 at 2:08pm
Cool. I will treat myself then!
Cheers Pete.
D.
A little knowledge is a dangerous thing...
2001 Super Air Nautique
1989 Fairline Corniche 31
www.bannrivercruises.co.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2020 at 5:20am
Originally posted by 2001SAN 2001SAN wrote:
I am in the UK.  I assume these would also work?
Sorry for jumping in!
Darren,
They look good. The key is the stem is removable so you can use a piece of wire to probe the drain hole for sediment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2001SAN Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2020 at 2:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebel skier Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2020 at 3:53pm
Do you guys put the McMaster-Carr: PN 4921K2 on the elbow to the side of the water pump too?  Is there enough clearance (85 351 pcm)?
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2020 at 6:16pm
Originally posted by frozenskier frozenskier wrote:
Originally posted by GottaSki GottaSki wrote:
Consider splicing in higher quality nylon, or brass garden hose ends, either at the engine, or the heater, makes for quick disconnects and purges.
Reverse the directions of the m/f. this way if the heater core ever pukes hard, three minutes you are on your way after connecting the hoses together.
I winterize with a shop vac, One hose clamp at the engine,  it pulls the water out of the heater core and lines, then pour a quart of af in.
it also catches all the drains, so don't have a bilge of water and rust/sediment.
Ok that sounds like it will work. Maybe I'm not understanding you, I think if I splice in anywhere it would be in the middle of the hose that is accessible so I can get to it easily. Reversing the m/f ends makes sense in the event of a core failure.
Indeed, accessibility is key
River Rat to Mole
Fast351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fast351 Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2020 at 5:59pm
I might have to get some of those 1/4" NPT ball valves.  Those look like the hot ticket for fall when I drain the block a handful of times for freeze protection before winterizing.
2001 Ski Nautique 196
2007 Air Nautique 211 TE
frozenskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frozenskier Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2020 at 4:49pm
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2020 at 2:55pm
Mark,
Careful with the type of valve you use. You need one tthat you can still get a piece of wire through it and into the block to probe the hole for sediment. Those do look like you can but with a reduced port size. I've been using these for years and have recommended them several times. The complete stem removes so it's full port for the wire for probing. I even see they are now offered at some marine suppies for block drains.
Installed those a few years ago.  They work great!
92 SN - Owned since 93
99 Pro Air
89 SN - Went to live on a lake in Texas
75 Donzi 16 - Sold in 93
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2020 at 1:40pm
Originally posted by ultrarunner ultrarunner wrote:
Don’t think for a second I’m still not trying to figure out getting the boat in my garage! Side load provides a challenge.
GT-40
I use a product called Auto Dolly by Merriick Machine. They work great to move the boat into tight spaces. I use a floor jack and pick up one side of the trailer. Then I slide one Auto Dolly under each tire and lower the trailer. Repeat for the other side. Once the Auto Dollies are in place, the boat can be positioned where wanted. A good smooth and level floor helps. The Merrick Machine units have heavy duty casters that roll well.
Link to Auto Dollies
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2020 at 1:16pm
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2020 at 1:06pm
Stick this in the end of one of the hoses running up to the heater core:
Post Options Post Options   Thanks (0) Thanks(0)   Quote frozenskier Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2020 at 12:59pm
another winterizing question. For a heater it is really a pain to get the hoses disconnected from the block to blow them out before adding anti freeze. Seems it would be easier if there is some type of fitting to put in the lines where they are more accessible? Ideas? Maybe there is a thread on this topic? Pictures?
DVskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DVskier Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2020 at 11:12pm
Yes to winterizing the shower as the hot/cold water hoses have water in them even thought the pump wasn’t activated. It only takes a couple of minutes to drain the system. I’ve had heater and shower on my boat since 1997. Only had one shower issue, the plastic manifold at the mixer cracked after a particularly cold winter. Easy fix, it was a heatercraft if I’m not mistaken. Heaters have leaked after 4-5 years likely due to delicate cores and pounding caused by rough water on occasion.
burban65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burban65 Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2020 at 9:50pm
Keno......I will take the under on your 48 more inputs..........now in another few weeks we may get to that number.
Question for the group - if one never uses the shower on the boats with the shower option does it still need to be part of the winterization?  I am new to the shower scene.......well you guys know what I mean.
SRB
Post Options Post Options   Thanks (1) Thanks(1)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2020 at 3:35pm
It’s lower than I thought. My 1996 SN, sitting on the Prestige trailer is 67” to top of windshield frame. Ground to top of bunks is 22”.
You should be fine unless you’re sitting way up on the trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frozenskier Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2020 at 2:10pm
Slight drift here, back to putting boat in garage. Does anyone know the height of the top of the windshield of a 2009 196 sitting on the trailer. I have a garage available for the first time and the opening is 81"s high. I've never had to worry about this before so I want to know the height before I commit. Boat is in water now and don't want to pull it out just to get measurement. Thanks, anyone?
DockDoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2020 at 5:00pm
Originally posted by JHadji JHadji wrote:
I'm curious, do you guys change the oil again in the spring with a fresh batch (VR1) or just once in the fall?
Hell no. VR1 is expensive! Once in the fall, that's it.
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2020 at 3:55pm
In the dry climate where I live (Utah) I change the oil and filter as part of my winter layup routine.  (Warm the engine up to normal operating temperature first).  Not a lot of opportunity for moisture in the air to find its way into the crankcase.  In the spring, re-commissioning goes quickly...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2020 at 3:31pm
No and here's some info on if oil goes bad by just sitting in an engne:
JHadji View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JHadji Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2020 at 2:30pm
I just winterized the blue tiger as well.  This year, I'm taking her underground to a limestone mine that was converted for storage of boats, RVs, etc.  Kind of a neat idea.  It's constant temperature, so I probably didn't have to do more than fog and loosen the belts, but I did the full monte of habit.
1988SkiNautique2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fast351 Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2020 at 8:06am
Hang on Fast351, 48 more people are lining up to tell you why in their opinion their method is better Wink
Oh yeah, I was expecting it.  More than one way to do it.  Doesn't bother me.  I know my way works and it goes pretty quick.  I don't begrudge other people doing it other ways though :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2020 at 8:45pm
I personally fog the cylinders / carb because... why not, it's cheap and seems generally recommended.
I also follow the manual's recommendation and loosen up the belts, remove the impeller, etc.
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2020 at 7:48pm
Where are the starboard side plugs hiding?
In the block there's only one on the starboard side. Forward near the RWP or alternator depending on who mainized the engine.On Fords, near the #1 cylinder.
