Engine Cleaner |
MrMcD ![]() Grand Poobah ![]() ![]() Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3776 |
![]() ![]() ![]() ![]() ![]() Posted: December-15-2020 at 2:23am |
The past few years I have been using a product called Purple Power, there is another brand with a similar name and both are citrus acid based so mostly bio degradable but both work very well. Spray it on, work it around with a stiff brush and wash it off with water. I have found it it spends much time on your hands you will get a minor skin burn so gloves are a good idea. Any polished aluminum you clean be sure to wash it off as soon as you get the grease lose. I have found if you leave it on polished aluminum it will leave a mark. I have cleaned several engines, transmissions differentials with this stuff. Local parts store sells a gallon for around $20 and it goes a long way.
OldSchoolBlue84 ![]() Gold Member ![]() ![]() Joined: December-02-2012 Location: Valparaiso, IN Status: Offline Points: 814 |
Kostas
1984 Ski Nautique 2001 |
jterr ![]() Gold Member ![]() Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
I don't remember the filter but I painted it Orange. I have a Painted Wix also Orange when I change the oil. Could be awhile but with both knees shot been having a hard time just getting around boat much less in it...
Fabcon ![]() Gold Member ![]() ![]() Joined: August-27-2012 Location: Buffalo. Mn Status: Offline Points: 554 |
I am sure it a wix he just painted it to match the valve covers
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out) |
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3009 |
+1 K&N Wix Mobil 1 JQ
John,
Next time you post your engine picture, take it from the other side so it doesn't show that Fram oil filter!
If you cover coil, distributor, alternator, solenoid switch, carburetor, etc. a steam cleaner will shine that bad boy up. A low pressure hot water pressure washer works, but be cautious and don’t get water / soap where it doesn’t belong. After, spray everything down with WD-40.
Just opened up motor cover and discovered my Filthy engine. Suggestions on how to clean without messing up stuff
