  New Posts New Posts RSS Feed - Steering cable
Steering cable
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Topic: Steering cable
    Posted: May-06-2023 at 7:29pm
Sounds like a plan. Wasn't sure if there was other objects in the way. Thanx !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2023 at 9:09pm
For rotary cables like yours, connect a rope at the front and pull out the back- then use the rope to pull the new from back to front. Would recommend lots of duct tape. Be patient, there are several other things in the same conduit- will take some coaxing.
Rack cables are harder, the more easily fed end is the large inflexible ram at the rear, so the process is reversed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2023 at 8:00pm
1988 - 2001 model . Replacing steering cable. Just curious from someone who has experience. Easier or more trouble free snaking new cable bow to stern or stern to bow. Going to connect new cable to old cable before pulling through. Does it matter which direction ?  Any tips ?
