  New Posts New Posts RSS Feed - Pitot Stabilizers
Pitot Stabilizers
trice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trice Quote  Post ReplyReply Direct Link To This Post Topic: Pitot Stabilizers
    Posted: July-04-2023 at 6:44pm
I will do all the above. Thanks Keno!
87 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2023 at 1:35pm
Not much you can do........blow air in one end and see if it comes out the other end. After that you can pressurize it to 25 to 30 psi and make sure air isn't leaking out anywhere.
If the boat is going 50 mph, the pitot tube and speedometer are seeing about 30 psi, so there's no real need to go any higher for most boats Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote trice Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2023 at 11:13pm
Replacing pitot tubing on an 85 SN. Is there a service/cleaning/operational check procedure for the inline brass stabilizers buried behind the gas tank?
87 SN
