  New Posts New Posts RSS Feed - broken seat base help
Barracuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Topic: broken seat base help
    Posted: March-14-2008 at 10:35am
Bremsen- Great job on the seat base repair!
Thanks for posting your step by step and including photos. This thread will certainly be one that many will reference when they have the seat base issue (I'd better check mine).
-Brad
Bremsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2007 at 10:30am
haha, thats why I take pics and post them on the internet. At least someone sees the work that went into it.
87, I know...they're almost embarrasing. I was going to buy some new ones but procrastinated too long. These would have been a real pain to paint so I just cleaned them up and greased them good. My only consolation is that you can't see them once the seat is in place. I'll probably replace them eventually b/c I know they're down there.
Jim, as far as I know you can still get them from the dealer. They may still be using the same ones on new boats, my boss has the same ones on his 99 pro air. I've heard they're around $40. I never checked the heavy truck places like Rudderdad suggested...but that sounds like a good idea since they're about as generic as seat sliders can be.
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2007 at 10:10pm
So, where do you get those fancy smancy sliding seat rails? I need some.
87BFN owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2007 at 9:35pm
You went through all that and didn't paint the track... What's with that??? Just giving you so crap the base looks great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2007 at 5:08am
Ryan, Looks like it will never break again! It's to bad most of it will be hidden so the good work you have done can't be seen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2007 at 10:23pm
Finished it all up over the last two weekends. I'm very pleased with the outcome.
Filled one more time with the kitty hair and then applied bondo
And then sanded....and sanded some more. Drilled the new holes and cleaned for primer.
Heavy build primer.
Wetsanded with 400grit
Painted
Assembled
Done!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2007 at 12:25pm
Thanks for the tip rudderdad. There are actually a lot of heavy truck places nearby so I'll see what they've got.
rudderdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudderdad Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2007 at 11:16pm
18 wheelers!! I mean go to a heavy truck dealer, (i.e. Peterbilt, Kenworth, Freightliner, etc.,) Their body shops do fiberglass everyday. Go to a 18 wheeler bone yard, and those seat rails are on nearly everyone of the trucks driver seats.
rudderdad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: May-01-2007 at 6:59am
I was mixing up about 5oz at a time which was just enough for one layer of 3/4oz mat. If the resin is setting too fast back off the MEKP a little.
To lay the mat down, I brush a light coat of resin on the base, then set the piece of mat on the part. I dip the brush back in the resin and then stab the ends of the bristles into the mat. You shouldn't 'brush' the mat. I keep doing that until the mat is just saturated and I can't see any air bubbles.
The front (tall) corners were the most difficult since the mat has to conform to a bunch of angles, so I tried to use smaller pieces for that area. In total I used about 5-6 layers of mat and 1 layer of cloth on the whole base. It's now solid as a rock.
Keep at it, you'll get the hang of it. I had never laid fiberglass before this project either. My only previous experience was autobody work, so I'm familiar with fillers and sanding. But thats it. I'm sure I made some mistakes, but thats all a part of learning.
88 Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88 Nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-01-2007 at 12:14am
I'm glad you hijacked this thread. I'm learning. I wish I could watch someone applying the matt. I've never seen anyone applying fiberglass. I've put one layer of matt on, but when I brush the resin on, the fibers get brushed off the matt and ball up on the brush. The layer went on good, and is good and strong, but I'm sure there is a better way of doing it. Or maybe not. Is this job supposed to be so messy?
Maybe explain to me how you apply the matt and resin. I still have more layers to put on, but I've been putting it off.
How much resin do you mix up at a time? I mixed up 3 oz. but it set up before I was finished. I should have read a book or something.Keep posting... I'm learning from it.
Kurt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2007 at 7:55pm
Well, I figured I'd give an update. It's no stringer/floor repair, but maybe someone will take something from it.
removed the clamps, everything held. I also stuck the broken corner back into place, it actually held its self.
I cut some smaller pieces to build up the corner a little.
The added another 2 layers of mat to the back side.
flipped the seat over and started topside. It was pretty badly cracked/broken.
Used the dremel to grind down the sharp edges and make a recess for the 'kitty hair'
I prefer Evercoat products, but as usual Bondo brand is all the local store had
Mixed it up and put a coat on.
Decided to put in a layer of cloth for added strength.
Back to the top, I sanded down the kitty hair. There are a couple spots I need to fill one more time before moving to bondo.
Back underneath I applied another layer of mat to the entire edge, and then finished up the whole underside with more mat. On the final layer I added the sanding wax to the resin per instructions.
After seeing I wasn't the only one with a base like this I wanted to make sure it didn't break again. I decided to cut off the lip underneath so that the entire edge sits against the floor. Hopefully that will prevent it from breaking again (only time will tell).
And thats where it sits for now. I will post one more update when its all done. Sorry for hijacking your post 88, hopefully it will help you or someone else down the road.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2007 at 8:22am
Actually, its 2-3 layers already, but I am going to add a lot more thickness to it. I just needed to hold its shape so I can remove the clamps and fix the corners. May even make the whole edge solid, but I'm not sure yet.
Peter, lol...you like the tyvek. Yes, I know it looks a little silly, but I didn't destroy any clothes and didn't get any fiberglass or resin on me. Very well worth the $6 IMO cause I tend to be a little messy when I work....you should see me eat ribs. I did get a lot of looks from neighbors driving by. Next round I am switching to disposable latex gloves.....those HD gloves are a bit cumbersome.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2007 at 7:39am
Yes, the 1 layer of mat isn't going to do it. I hope your'e adding more.
Ryan, It looks like your'e ready to go out on a Haz Mat emergency responce!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88 Nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2007 at 6:09am
Ryan,
Are youu going to build up the outer flange area to support the weight so it doesn't crack again?
emccallum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote emccallum Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2007 at 9:36pm
You look like an expert!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2007 at 8:53pm
Here is how I did mine. Pretty much what everyone else has suggested.
Braced and reformed close to original shape
Grinded/smoothed the cracks. Then sanded with 60grit. (wish I would have filled the cracks with kitty hair, but oh well).
Cut/tear some glass mat into 2-3" squares. Mix up some resin, brush some onto the surface, lay the mat down and dab the brush to saturate the mat. Finally, roll out the air bubbles
This is where I left it.
Next weekend I'll remove the clamps, fix the corners and lay more mat down on the entire base. I'll fill the top cracks with kitty hair and smooth with bondo. Then paint. Good thing to know about the seat tracks, I've got mine working, but $40 for new ones sounds like a good price.
I purchased all my supplies at UScomposites. This is my first venture into fiberglass and have to agree with everyone else....its not that bad at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2007 at 6:56am
88, I would really rough up the surface with a grinder. I don't think you need to go all the way to the base glass. Wipe it down with acetone. Building up the flange with layers of glass is a great idea. The wood would work but we have enough rot on this site already!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88 Nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2007 at 2:39pm
I'm ready to make the repairs on my pedistal. I'm building a wooden frame and the pedistal will sit upside down on the frame. The frame will hold the outer flange while I weigh the pedistal down to hold the flange to it's origional position. I have sanded where I will put the strips of mat.
My questions:
1. Do I need so sand clear down to the fiberglass or just rough up the surface?
2. Do I need to clean the sanded surface with anything before I start?
3. David F sugested 1/4" wooden strips under the flange to support the weight. Could I just build that up with fiberglass matt or should I use wood strips encased in fiberglass?
Thanks all
Kurt
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: January-12-2007 at 10:11am
I upgraded the seat in my '77 Martinique with that exact seat base and then had the same failure shortly thereafter. The solution is to add 1/4" thick ( or so) strips of wood under the flange before you screw it to the floor. The wood helps support the seat base and thus no cracking.
PLBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLBC Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2007 at 8:49am
3 brackets along front and back and 2 on each side.10 dollars in material plus whatever the new rails cost.
99
MaddMarxx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2007 at 2:11am
When I worked at "cc" I made a few of those, they came in (white,taffy,gray,lt blue) If you don't want to fix it yourself, send it to me I will fix it for you!!
If not maybe..Nautiquefanatic has one he wants to sell..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88 Nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2007 at 12:56am
Thanks BlondieGurl. It looked pretty pathetic didn't it. "Kurt has 0 friends"
Now I have one friend in there.
Kurt
BlondieGurl1443 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlondieGurl1443 Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2007 at 7:12pm
hey Kurt, i visited ur myspace and i sent you a friend request!!! it looked liked you needed a friend!
PLBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLBC Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2007 at 3:35pm
Yep, the base was way over 200, no hardware either. New sliding rails were about 20 a piece IIRC. I'll post some pictures later.
99
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2007 at 2:26pm
It was definitely mid-high $2xx, I figure after shipping I didn't want to low ball anyone on an estimate.
All the edges were cracked completely off of ours, threw a couple L-brackets on each side and it's rock solid and doesn't look too bad, the seat hides it pretty well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2007 at 2:01pm
Originally posted by SkiBum SkiBum wrote:
By the way, I have a silly question for you. Which way does the base face? Does the lower end of the slope face the bow? My seats have been out for a month and I can't remember.
Nope, the other way. Tilts the seat back a bit.
BTW, $300 for the base from CC? What a joke.
SkiBum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SkiBum Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2007 at 10:31am
It is a really easy repair. I agree with TRBenj, you don't have to do the outside if you want to protect the gel cote appearance. Give it a try. You will learn a little about working with fibergla$$. You will save a lot of money. You can take pride in your craftsmanship when finished.
Bill
http://www.freewebs.com/billsboatworks
www.freewebs.com/billsboatworks 1987 SN Rebuild Project
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2007 at 10:12am
By repairing it yourself you can make better than it ever was. its one of those things that your afraid to dive into and when its done you say that was'nt bad at all,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2007 at 9:52am
If youre really picky, the piece (or similar) may still be available from CC
~$300, repair it yourself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2007 at 8:54am
I agree with SkiBum, that can be repaired with gla$$. The only problem being that the exterior is gelcoat (I think) so I would try and keep the gla$$ on the inside for aesthetic purposes. If youre really picky, the piece (or similar) may still be available from CC- the seat base hasnt changed that much over the years.
