  New Posts New Posts RSS Feed - morris hydrolic steering
doug e View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doug e Quote  Post ReplyReply Direct Link To This Post Topic: morris hydrolic steering
    Posted: March-23-2007 at 11:30am
Thanks for the help, a local trans. shop found me a good replacement for it!!!
Cheap thrill fishing team
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2007 at 1:25pm
Doug, Look in your yellow pages under power tranmission to see whats close to you. This is not the transmision in you car catagory!! It's sprockets,gears,bearings,motors,drive belts,etc. and of coarse seals. Keep in mind that there may be internal wear in the helm that caused the seal to fail. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doug e Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2007 at 12:56pm
It's the helm seal (the one that pops out), I took the seal to the local marine dist. and nothing he had matched up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2007 at 11:23am
Doug, If it's just a bad seal, then it may be located through a industrial power transmission supply. If it's a shaft or cylinder, it's probably a standard off the shelf seal and should have a # printed on it. However, a bad seal may be caused by internal wear so go by what the boat dr. says and look into it farther.
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2007 at 10:27am
Doug, is the helm leaking or is it the cyl.
I don't see any parts nor listing for the Morse hyd. steering,Sea star,made by Teleflex /Morse,also Baystar,same Co.
You may have to replace the unit.......boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote doug e Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2007 at 9:54am
I have an morris hydrolic helm with a bad seal, does anyone know where to get parts for one?? Thanks
