  New Posts New Posts RSS Feed - 88 Martinique aft railing
Dabblin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dabblin Quote  Post ReplyReply Direct Link To This Post Topic: 88 Martinique aft railing
    Posted: October-19-2007 at 6:15am
The front of the railing is an aprox 1/8" threaded piece that is secured from the bottom.
Its a b#@tch to get to but needs to be checked,the nut probably came off allowing the rail to start pivoting on the bolt plates at the stern stand off legs. I had to pull the bin under the rear deck to get to them.
You might also look for a small machine or fabrication shop. The work with all sorts of stuff. Stainless is no sweat for then. Ditto on the tacking it before removal. Its not just the screw holes the angle of the leg has to be correct, if its left/right or fore/aft alignment is wrong it will stress the weld again and probly stress crack the gel coat when you tighten into place.
Good luck
87 Martinique
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2007 at 12:42pm
Cannot add to pete's fix,tack the breaks first then remove.Heli-arc will give the strongest weld,some discoloration will result.
Second choice is a new assy. this will be pricey tho..........
Good looking boat............
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2007 at 1:30pm
Originally posted by jlhowe jlhowe wrote:
No, no one hit me.
Actually it happened when people climb up on the swim platform and grab the rail to pull themselves up.
Maybe the welding shop can beef it up on the inside were you can't see it. Like adding a smaller tube inside and welding that to the base as well.
jlhowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlhowe Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2007 at 1:21pm
No, no one hit me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2007 at 9:12am
jl, From looking at your pictures, it looks like having them re welded may be your only option. I'm not aware of a female socket type base that would replace the exsisting. The smallest ones made are for 7/8" OD but the angles I don't believe are shallow enough. You shoud plan on taking the boat to a weld shop so he can tack weld first and then remove the railing to finish welding. If he doesn't tack first, the position of the base screw holes will be hard to match. After welding, he can chemically remove the heat tint from the weld or buff them out.
Did someone hit you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlhowe Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2007 at 3:41pm
Sorry for the long delay. Here are some pics. Boat dr or anyone else have a good idea of how to fix?
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlhowe Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2007 at 2:40pm
Will do...thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2007 at 2:34pm
shoot me a pic and I might have what you need..........boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlhowe Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2007 at 2:30pm
Two vertical posts on aft railing have broken off where welded to the base. What is the best way to repair? Weld? I've tried to locate 1/2" round base fitting without success. Thanks.
