  New Posts New Posts RSS Feed - Vibration
Vibration
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Topic: Vibration
    Posted: July-19-2007 at 10:11am
Luke, you have learned well
SkiBum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SkiBum Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2007 at 10:00am
You can check for a bent shaft by disconnecting the shaft at the coupler then carefully observe the gap between the shaft and coupler as you slowly rotate the shaft. If the gap is consistent while the shaft rotates then you may only have an alignment problem. If the thickness of the gap varies as you rotate the shaft then the shaft is suspect.
Bill
http://www.freewebs.com/billsboatworks
www.freewebs.com/billsboatworks 1987 SN Rebuild Project
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2007 at 8:57am
Chad, Have you had the boat for a while and this vibration is new? If you just got it, then you may not be used to the harmonics at certain speeds. Hull harmonics can be so bad that they do create problems but it is hard to stop them at times. It's like stopping a bell from ringing. I've heard that CC is having big time problems with towers on some boats. do check your prop,shaft,alignment and cutlass bearing.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2007 at 6:49pm
Yup, likely.
Engine off, can you easily turn the shaft coupler by hand?
(Notice it was challenging to word this without becoming Hollywood's new sig.)
River Rat to Mole
ande26 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ande26 Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2007 at 6:16pm
I have a viration when I accelerate and it smooths out around 32-34mph. I think it might have a bent shaft or bad prop. Any suggestions or Ideas. Thanks for your time.
Chad
