  New Posts New Posts RSS Feed - Stupid Electrical Issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Topic: Stupid Electrical Issue
    Posted: August-02-2007 at 1:52pm
Originally posted by summitnautique summitnautique wrote:
I already checked it on both the block and the battery. Would you guys rule out anything on engine at this point and focus on the dash wiring?
A visual check to see if it's simply connected, or a specific voltage check? It sounds like it's a loose/corroded battery cable at either the block or battery (more likely battery terminals). Try remove and reinstall and see what happens.
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2007 at 1:08pm
I've got a reset button on the rear of my engine. I don't know if yours has a similiar device or if it has anything to do with the problem, but what the hey. And with vehicle electrical systems, I wouldn't rule out anything.
Good luck, Steve
Play hard, life's not a trial run.
'85 BFN
'90 BFN
White Lake, Michigan
summitnautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote summitnautique Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2007 at 12:49pm
Thanks for help guys. I already checked it on both the block and the battery. Would you guys rule out anything on engine at this point and focus on the dash wiring? Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2007 at 10:31am
Last Friday we had the same thing happen after 1 hour of footing. This one was simple. The negative cable pulled out of the terminal end on the block. Like nutty said, are you using the negative on the battery or the block when you are testing? I'm not questioning your skills, just throwing out an obvious problem.
Tull
'85 BFN
'90 BFN
nuttyskier2002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2007 at 5:17am
When you are reading power on your ignition switch where is your meter grounded at? Battery? Engine block? Should read the same at either place.
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2007 at 1:56am
Could you have a bad ground issue?/ Try cleaning both ends of your neg battery cable? just my first thought...
64 American Skier
62 Classic..
73 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote summitnautique Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2007 at 12:53am
So after finally getting the boat to run right at altitude now this. '87 Nautique 2001. Out skiing having a great time tried to restart the boat after sitting for awhile...nothing...thought maybe neutral switch was off...that was okay. Notice that no dash functions are working, blower, horn, etc. Boat is completely dead. Back at home. Check power from battery to engine with multi-meter its okay. Ended at ignition switch that is getting power at both ends. Tried to skip that still nothing. No, idea what else it could be. Any thoughts would be great. Thanks.
