  New Posts New Posts RSS Feed - 1982 Ski Nautique Engine Grinding Noise
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Topic: 1982 Ski Nautique Engine Grinding Noise
    Posted: August-28-2007 at 2:01am
Originally posted by eric lavine eric lavine wrote:
I try to keep business as business, but i do have a friends and family stash of Sachs plates, i advertise subliminally, if you need one I'll send you one. Eric
Consider one of those sold
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2007 at 12:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2007 at 11:07am
Do not go to Skidim because they don't handle the good Sachs plate. Do a search for it. Even better, let your friends use they boat and trash it ! They can then pay for a plate and a trans rebuild.
Sachs drive plate
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2007 at 10:47pm
buy a new one from discount marine through here brandon and recieve a 10% discount...
wakeboarder08 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboarder08 Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2007 at 4:44pm
http://cgi.ebay.com/ebaymotors/Ford-351W-Marine-Velvet-Drive-Transmission-Damper-Plate_W0QQcmdZViewItemQQcategoryZ124104QQihZ017QQitemZ270156966438QQrdZ1QQsspagenameZWDVW
Is this the same damper plate that you are suggesting might need to be put in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboarder08 Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2007 at 2:43pm
actually the only time the noise ever gets made is when the boat is in neutral. When it is in reverse and drive the boat drives perfectly. The noise is only being made while in neutral. Is this still going to be the damper plate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2007 at 12:36pm
BTW, dont dis-appoint your buddies, if the noise goes away in nuetral i would take it out....make sure you bring a paddle with you, after today it does need attention though
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2007 at 12:33pm
sounds like you need a $4000.00 rebuild...
JK   your damper plate probably needs to be replaced, it costs about 90 bucks and is bolted to your flywheel, its not a good idea to keep running it, if your car was knocking would you keep driving it?
does the noise go away with rpm? if so it is your damper, but your planetaries are turning in nuetral too that is a possibility but i doubt it, go after the damper first and make sure you check the alignment, by the way rebuilds arent that expensive
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboarder08 Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2007 at 3:58am
also, some of my friends want to take it out in the morning. Is this a bad idea? Could I possibly mess it up more?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboarder08 Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2007 at 3:36am
ok, so i bought an 1982 Ski Nautique 2001. I took it to the lake today and it was running great, cranks up everytime very easily. I rode it around for about an hour, and when coming back in when i switched it to neutral it makes this grinding noise, exactly the sound of grinding gears in a standard truck. It only makes this noise in neutral, not forward or reverse. Anybody have this problem or know where i need to start?
