  New Posts New Posts RSS Feed - Odd find in my shop
Odd find in my shop
 Post Reply Post Reply Page   123 4>
Geno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geno Quote  Post ReplyReply Direct Link To This Post Topic: Odd find in my shop
    Posted: September-24-2007 at 12:41pm
Thanks Pete - trim tabs will be added after we get a finish on the hull.
Does anyone know where to get the little cowlings or covers for the engine compartment vents?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2007 at 12:36pm
Geno, All the rear engines were slow to get up on plane and most had trim tabs added. I even think the later versions had them from the factory. The single tab on your boat is non functional. Someone didn't do their homework!! To work properly you need two tabs and they must be mounted flush with the bottom of the boat. The self adjusting spring loaded ones work great. The only drawback to tabs are a few MPH at WOT.
p/allen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2007 at 1:35am
Thats cool to hear . Im glad you got the beast running with only a few minor adjustments . Good luck with the rest of the project .
Pat
My 72 Skier
Rock River
Dixon,ILL.
Geno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geno Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2007 at 11:54pm
First off - Inland was dry as a bone. Record drought has her about twelve feet low and we couldn't launch from either end. We then proceeded to Guntersville and launched next to the Holiday Inn.
No pics - the wife got flustered becuase as she parked the truck and trailer after launch she mangled the aft starboard side of a brand new Stratos trailer - it happens that the guy who owned it is down from SC for a championship tournament with a really high payout. That's his job - to fish. Left him a note and now we have to fix his stuff before we can continue to fix up ours. Leave it to my wife to pick the most expensive thing in the parking lot to run over.
The boat ran great for about ten minutes, sputtered once and conked out. Smoke was pouring from the engine compartment so I grabbed the fire ext on my way to the engine - of course water washed into the engine box. Luckily it was only a moderate electrical fire and was easily put out by pulling the offending hot wire and waiting for the smoke to clear. Half a roll of electrical tape and a new jump (routed away from anything hot that would melt the insulation and ground it out) later and we were back underway.
41.2 mph is all she'll do but I'm certain the carb secondaries are non-functional. Will pull, clean up and replace the carb soon. The engine, velvet drive and v-drive all performed flawlessly. The tranny or v-drive or both are making some noise but it's only audible at idle and doesn't sound bad - no clunking, growling, grinding or anything of that nature.
She's slow coming out of the hole and points her nose skyward (which spooked the snot out of the wife and stepson LMAO!!) for a good 15 seconds before she hops up on plane.
The good thing is that even though she's quite ugly with her primer and greasy fingerprint paint scheme, she drew attention from almost everyone. It seems there are a lot more Correct Craft aficionados out there than I would have ever thought.
Geno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geno Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2007 at 4:30pm
Okay - got the engine running and she sounds lovely. It still has the rusty carb on it and it seems to work fine so I'm going to warm it up on Inland Lake this afternoon.
It wasn't easy as my stepdad had a morrass of wires with no color actually meaning anything running everywhere and I couldn't get the coil/ignition to heat up from the front no matter what. I rigged a jump from the battery to the power block that heats up the coil, ignition and fuel pump and she fired right up as if she had been running yesterday. On three year old fuel even. Going to pump out the old fuel and fill her up in just a few minutes on the way to the lake.
Anybody know where I can get the little cowls that go over the engine compartment vents? In chrome maybe? Finally got my body man over to look at her and she isn't going to be too hard to paint. I'm pulling everything off her in the next few days to prep for paint. The interior is still usable if not quite perfect. Found the back seat in the old garage so I have everything for her except the original cover. I'll have one made this winter sometime.
All the chrome is in good shape except the fuel fill neck - it will have to be rechromed. All the dash lights work, the guages all seem to work, the shift and throttle cables are like new, the front light works, the rear light works, the trailer is in good shape but everything needs new paint. The prop does have a ding in the leading edge on one blade so that'll have to be repaired before I polish the prop out.
Will post a pic or two and a top speed upon return from the lake.
nautique frk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautique frk Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2007 at 2:22pm
Pete, My Separator came from the Upstate South Carolina area, I believe I am second or third owner.
69 Mustang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 69 Mustang Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2007 at 1:55am
That is one cool boat, and will look great no matter what you do (within reason). But IMHO red boats are a b*tch to maintain with regard to the finish. Used to own one, hated trying to bring the color back 3 - 4 times each season.
"Where the **** are we?" Amelia Earhart. July 2, 1937
MaddMarxx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2007 at 1:27am
I would do that boat all gloss black with red interior!
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2007 at 1:16am
MM; Think I'd rather you post pics of fat chicks than that awful gator boat.
Paul; He might do red with white stripes but he'd haveta go some to beat that crew you have on your boat.
john
"Loud pipes save lives"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 10:15pm
Mike, Were did you get your separator? Do you know what part of the country it came from? It sure looks great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautique frk Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 8:14pm
Pete.
My separator is white hull with red stripe on the side and red racing stripes on the top deck. It is pictured in the Diaries when I got it.
Red interior.
67nautique312 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67nautique312 Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 6:55pm
Skicat,
Nice red boat you have......Any stripes yet??????
1963 Classic (handed down to my daughter)
67 Riviera
68 barracuda
1971 Ski Nautique Promo
86 Silver Nautique
1995 Ski Nautique
racintj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote racintj Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 6:12pm
Oh my gosh, now it would really depreciate if it had anything close to UGA or a dawg on it. Now Orange and Blue, that would be a gorgeous boat. Great post MM, that's what I'm talkin' about. Welcome to the 'Swamp' boys.
Geno, congrats and great find on the boat. You'll be in good hands with this forum.
Every day above ground is a Good day.
Lakeland, FL
skicat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 6:12pm
Boy MM,
That is a waste of good fiberglass!!!!!!
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 6:10pm
Hey Paul,
Do as I say, not as I do?
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 6:10pm
skicat...Your "UGA" boat will get a beatdown from this boat!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67nautique312 Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 6:01pm
Geno,
why don't you add some stripes......Hi pete how are you old buddy?
Just kidding! Definatly Original is the way to go with this thing!
67 Riviera
68 barracuda
86 Silver Nautique
1995 Ski Nautique
Geno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geno Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 5:52pm
Geno, This would be the red color but a slightly deeper red as the colors in the catalogs tend to be washed out. The deck and hull would have both been red.
This is her new color scheme - I can live with it just fine.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 3:53pm
Originally posted by skicat skicat wrote:
Bright red isn't Bama. That's for us Georgia boys!
Some of named Greg in Georgia like bright yellow?!!?   LOL
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 3:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 3:47pm
I've got a boat just her color!
One of these days it is going to have white interior with red piping (and a big UGA emblem on the deck).
Greg
86 BFN
Geno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geno Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 3:36pm
Boy Geno,
All of that U of A talk is really depreciating the value of that used to be cool boat!
I would never do that!! LMAO!!
My wife's nickname is bamagirl and it has nothing to do with UA and everything to do with the fact that her family's from AL and she was an Air Force brat raised all over the world. Her favorite color on anything is bright red (I can't drive her cars because I get the tickets she can get out of). I like white boats so red below the rub rail and white above would be a nice compromise and visually pleasing as well.
I wish we could find a pic of the redcoat color scheme from 72.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 3:29pm
Boy Geno,
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 3:27pm
Originally posted by Mojo Mojo wrote:
Where's Pete?????
LMAO!!!
1988 BFN-sold
Geno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geno Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 3:15pm
The 68 spoiler is the same color as my tub but she has a few differences: the vents are chrome on the 68 and my vents are glass, the 68 has two vents on the for edge of the engine hatch and mine has none.
Geno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geno Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 2:56pm
Thanks 75 Tique. I've mostly been around OB and IO.
My stepdad made it easy to hose cool it though - if you look at the pics of the v drive you'll see a tee, valve and extra hose that's red in color (and doesn't belong) running vertically from the port v drive cooling hose. That is actually an industrial grade water hose with a cap on it - you unscrew the cap and screw a water hose directly onto it. Not stock but not a bad idea at all, no pulling clamps and reclamping needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 2:50pm
Geno,
Not sure how much you've been around boats, so don't be offended with this little piece of advice if you are already aware. If you do manage to get it started this weekend, don't run the motor without running water through it. Easiest way is to pull the intake hose off the thru-hull water intake fitting, stick a garden hose in it, and retighten the clamp.
Second, don't "test out" the transmission by putting it in gear. The shaft should not turn in the shaft log or strut without being in the water, or you will fry the bearings.
Geno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geno Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 2:46pm
Red hull and white top with red vents. Maybe a red engine cover as well?
In deference to Pete the trailer will stay the original white.
What about a really big U of A decal on the top front?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 2:39pm
Moj, I'm right here and looking in the ref. section for the Pete approved colors!! Too bad we are missing the 69 and 70 years. The 68 as shown is really a Spoiler in the green color that I think Geno has. Then we skip to 71 and white was the only color but then in 72 concord blue, lynn green, salem orange and redcoat were offered.
Nautique frk, what is the color and year of yours?
I know we found the blue for a alternate color to the yellow for the phantomkaw but that was a Torino!!
We really need to find someone with the 69 and 70 catalogs to fill in the blanks!!
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2007 at 2:32pm
Originally posted by Geno Geno wrote:
LoL
You guys won't want it after I paint her red and white and put Bamagirl on the transom.
Where's Pete?????
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
