minor hull repair |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
Posted: December-11-2007 at 11:21am |
Bill, having gelcoat repaired- even if its a very minor repair- for $75 sounds like the deal of the century. I dont think thats a typical price for gelcoat work! |
76'SN
Groupie Joined: August-20-2007 Location: United States Status: Offline Points: 60 |
thanks for all of the insight. ive actually looked into several gel coat repair kits but since the problem areas are on the bottom i wasn't really planning on putting a whole lot into it. there is a scratch from one of the runners on the trailer and the other is up towards the bow i guess from beaching. just wasn't sure if there were any tricks that turned out decent as alternatives.
hukt on fonix helpt me
TRDon
Groupie Joined: December-22-2006 Location: United States Status: Offline Points: 65 |
I went the cheap route and did a plastic welder epoxy. It was 4 bux and waterproof, dries in 24 hours, is hard in 15 minutes and has lasted 5 years without wear. It was underneath so I really didnt care much about how it looked just that it sealed.
85 2001 351 240hp FS
93 sport |
bill1
Senior Member Joined: May-27-2007 Location: United States Status: Offline Points: 151 |
yeh Pete, you did suggest a Minicraft kit. But let someone who does this everyday for $75 is a lot less than me ordering a kit and doing it myself for $100. And with the damage on the bottom side of an 81SN, the $75 option here worked better for me.
bill
Chad, Here's what I was referring to:
gelcoat kits at West This is a universal kit that you use the tints that come with the kit to come close to the color you need. You mentioned the scratches are on the bottom anyway! Bill, I seem to remember that you were looking for a good match and the reason you looked at a Minicraft kit. |
bill1
Find a local or nearby fiberglass shop. they can get pretty close on matching to color. I priced a gelcoat repair kit a couple of months ago and the smallest kit was 100 bucks after you give them a color to match it to. You still have to do the work. A local shop here patched and repaired 3 different places on my boat for 75 bucks.
If it's a new boat, yes, get the kit so it will be matched more closely. It it's an older boat like mine, take it and let someone else do it. |
bill
Chad, Go with one of the gel coat repair kits you find at a marine supply. I wouldn't use Bondo unless you are planning on doing a complete re gel of the whole hull.
76'SN
just curious about a small touch up job on the under side of my nautique. there are 2 or 3 fairly deep scratches that i was told to use bondo to fill in. will this work or is there a better solution. they are not deep enough to leak water.
