Best Material to use to Repalce Floor |
Jared Johnston
Newbie Joined: September-08-2005 Location: United States Status: Offline Points: 31 |
Posted: November-15-2005 at 1:55pm |
I've replaced my floor with plastic cores and PVC sheets. I first poured foam into the stringer gaps, sanded and leveled off and then sanded the foam down flat. After that, I glued and screwed down a layer of 1/8th inch PVC sheeting (after grinding both sides for adhesion). Then I took 1/2 inch plastic core honneycomb (with film and barriers) and glued the honneycomb down to the PVC using epoxy and adhesive compound additive. Next I covered the entire floor with a good solid 2 layers of glass with epoxy. I'm making the rear floor piece out of the same materials. She's about done with the floor work. I'm moving on to the paint/finish next.
A boat is just a hole in the water to toss your money into. Here is mine! http://www.correctcraftfan.com/diaries/details.asp?ID=865&sort=&pagenum=1&yrstart=1976&yrend=1980
David F
As there are many good methods to installing or replacing floors, I am sure you method will perform very well. The only thing I would add to your write-up is the importance of sealing the screw holes prior to installing the fasteners. After the hole is pre-drilled and countersunk, you should seal the now exposed wood with epoxy resin (or similiar). The water will find that screw hole and start to rot the wood around it. |
Rick
Senior Member Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
66 If there is ever a war can I come hide under your boat!! On my 66 barracuda I used exterior grade plywood with 2 coats of urethane after I bondoed the voids in the edges. I figure it is good for another 25 years.
66polyhead
Senior Member Joined: December-20-2003 Location: United States Status: Offline Points: 171 |
I pulled up a floor in mine that had been previously replaced using 3/8" "exterior grade" plywood, resin coated, bottom only. It was poor grade, filled with voids, and only 4 layers. I replaced the original bulkheads, middle, and rear, and forward, with new crossmembers made from White Oak. Cut, planed, triple resin coated. I anchored the laterals into the primary stringers with a 3/16"X1 1/4"X 1 1/4"X 4" angles and stainless TEK screws, Into the secondary stringers with # 10 X 1 1/4" stainless wood screws (you have to be careful not to pilot drill thru the hull on these puppies). Then I used 17/32" 8 layer high grade plywood, coated three times, with a urethane resin, 6 coats on the edges. I used a construction adhesive on top of the stringers and all the laterals (oh yeah, i put in a few extras, under the seats, and the shaft packing access, and front battery access), laid the floor down in 4 pieces, and screwed it down after pilot drilling and countersinking, with the same #10 X 1 1/2" stainless steel flat head screws. Glue, carpet, and now I can have a watersking Elephant on board!
jimbo
As I understand it, the difference in Marine Grade Plywood and Exterior Grade is the Marine Grade is more structually sound. The knots and voids in each of the inner plys are repaired and filled on the marine grade but not exterior grade. Both use water-resistant glues. I'd use Marine Grade Plywood and encapsulate it with fiberglass mat and epoxy. Treated plywood would be resistant to rot but would still soak up water if not encapsulated.
David F
An alternative to marine plywood is pressure treated plywood that is first allowed to "dry" several weeks in the sun prior to using. The advantage over marine plywood is the rot resistance of pressure treated plywood. The disadvantage is that it is not a structural grade plywood. Either choice must be totally encased/sealed with epoxy resin and/or fiberglass once installation is complete.
91nauspor
Guest |
west systems 2 part on marine plywood.
79nautique
you glass over anything that you plan on using. Even if you use composite starboard you have to glass over the seams to seal the wood that is already there.
SkiLew
Groupie Joined: May-20-2004 Location: United States Status: Offline Points: 73 |
Did you also glass over the plywood?
pmt2234
Guest |
I used 1 piece of resin coated treated plywood to replace the variety of very very rotten floorboards under the glass of my '84 2001.
mrese
Groupie Joined: February-18-2004 Location: Al Status: Offline Points: 93 |
I replaced my trailer running boards with a marine polyboard. It comes in the same sizes and works very much like plywood(cutting, glueing, screwing, and stapling). The prices were comparable to the marine plywood I looked at, but it seems to be lower maintance. Do some looking on the web and find a dealer you can drive to and pick it up. Shipping and Handling would be outragous. The marine quality resist water absorbtion much better, otherwise the "plastic" eventually soaks up some water and gets brittle.
SkiLew
What is the best material to use to repalce the floor in my 1978 CC? Is it marine plywood, treated plywood, or some type of non-wood composite. And if it is a non-wood composite where would I get this material?
SkiLew |
