  New Posts New Posts RSS Feed - Circuit Breakers
Circuit Breakers
Bremsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Topic: Circuit Breakers
    Posted: March-16-2008 at 11:41pm
Blazer, we couldn't figure out the little red lights either. Ended up clipping each one off and adding terminals to re-install.
Blazer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blazer Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2008 at 1:14pm
I ended up buying the breakers from Skidim. The order arrived within a couple of days. I installed them yesterday and all is working well again.
I went ahead and replaced all of the female connectors while I was in the dash. SOme of them were corroded to the point they broke off when I pulled the dash plate.
I will have to re-install them in the new dash plate when I order it, but we are functional once again. Thanks to all for the info.
ONe question about the red indicator lights. When I get ready to install the new dash plate. DO they just puch out? Does the black ring on the outside come off?
I didn't spend much time looking at them, but wondered how they come out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blazer Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2008 at 4:37pm
Thanks. I plan to pull the remaining breakers this weekend. I need to re-work some of the wiring while I am under the dash.
I appreciate the leads.
azeus17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote azeus17 Quote  Post ReplyReply Direct Link To This Post Posted: March-04-2008 at 1:58pm
I bought from Skidim last year. They are very helpful and can tell you what amp rating each of them should be.
Boats:
Current: 02 SANTE
Sold: 89 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: March-04-2008 at 1:09pm
ouch, WL is a little pricey on those. Skidim also sells them.
http://www.skidim.com/products.asp?dept=1039
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blazer Quote  Post ReplyReply Direct Link To This Post Posted: March-04-2008 at 12:13pm
Thanks for the lead. I will pull the remainder from the dash this week and order accordingly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2008 at 9:13pm
White Lake sells the breakers. They dont all have the same current rating- they range from 2.5 to 20A.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blazer Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2008 at 9:00pm
I own a 1989 Ski Nautique 2001. I need to replace some/all of the circuit breakers in the dash.
I can't seem to find them locally. Any sources for the E-T-A 2-5700-IG1-P10-DD-2.5 or acceptable subsitutes will be appreciated.
I have only pulled one from the dash. Does anyone know off hand if they are all 2.5 amp?
