  New Posts New Posts RSS Feed - Exhaust leak, location?
83_2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83_2001 Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust leak, location?
    Posted: May-07-2008 at 5:30pm
It appears I have a leak in my Starboard side exhaust hose, I just noticed it while starting my Nauti up for the first time this year on the Fake 'a Lake. First Question, the flooring that runs from the dog house to the gas tank has a section that looks to be the same width of the dog house (83 Ski Nautique) Should I be able to just lift this portion of the floor out without unscrewing, unbolting, ect. Also, I was able to to see that the leak must be coming from this area, as there was no leak evident at the exhaust through hull fittings back by the gas tank. If it is the "rubber" hosing, any ideas for a quick fix, I thought I had seen a mention of JB weld once.... Something to get me on the water until the replacement arrives. Thanks in advance for any help.
MADTOWN78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MADTOWN78 Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2008 at 6:08pm
You should be able to lift it off if the carpet divides at that section also. It is apparently screwed down (screws are hidden under the dog house and behind the back seat)? This is just what I have been told by helpful others -- I can't verify for sure since my 78 SN was not in original condition when I pulled up this section.
It only took me 3 days to get replacement hose. It might just be a loose hose clamp.
livin', lovin', lovin' livin'
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2008 at 6:39pm
No temporary fixes, that hose is underwater, that exhaust leak is a potential water leak that will sink your ship. My panel simply lifts out after you pull the pins on the doghouse and remove the panel behind the back seat back. Pete mentioned screws the other day but I have seen no evidence of them on my 83 or of holes into the stringer where they once would have been.
azeus17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote azeus17 Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2008 at 6:58pm
83-
Not sure if it is the same as my 89 Sport, but to get that floor section out of mine, you have to remove the rear bench seat by pulling the two pins under the seat. Then remove the dog house by opening and pulling the pins at the rear. It should then come right out. Mine was not bolt down or anything like that.
I am sure someone with an 83 will correct me if I am wrong.
Adam
Boats:
Current: 02 SANTE
Sold: 89 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2008 at 7:16pm
Adam
and here I thought I already did..
Post Options Post Options   Thanks (0) Thanks(0)   Quote azeus17 Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2008 at 7:47pm
Yeah, sorry about that Joe. I got distracted at work while I was typing and you got your post in before me.
This work thing is really cutting into my CCF time!
Boats:
Current: 02 SANTE
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2008 at 1:59am
It really stinks when work takes a person away from C/CFAN...even if you are at work, on the clock and on their computer.
LOL Adam.
john
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2008 at 8:20pm
The leak is probably coming from the fiberglass mufflers that have cracked at the hose fitting(s). An easy repair if you know how to do fiberglass work...and even if you don't.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2008 at 1:16am
David F, where have you been?
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2008 at 11:53am
Hey Tim:
Just working too hard on renovating a house and work. I explained it to JBear on this thread
