Transmission squeal |
Post Reply | Page <12 |
bkhallpass
Did this on our 58 Trojan for 20 years. BKH |
Livin' the Dream
Barracuda
Wow- this thread got a lot of mileage for a loose belt. My buddy's MC has old worn out belts and it squeels every time he fires it up in the water.
replace/ tighten the belts and if that doesn't solve the problem, you've at least removed one variable from your troubleshooting list. Good Luck |
I actually thoght it was a mouse on the boat
I thought that MC's always squeel! Sort of like a stuck pig! |
boat dr
Pete,that is like saying your best friends old lady is not just ugly but she is fat too.
We have to love them all,not everyone CAN OWN A C/C..........boat dr |
mopeds...fun to ride
gigem75
Senior Member Joined: November-12-2005 Location: United States Status: Offline Points: 239 |
We're going to have to get our stories straight. In another thread it was stated that the water the the cylinders probably came from him not draining the engine before he pulled the heads. If that is correct then there should be water at the rwp which would provide the lubrication for a second or two of running. If not, the debate continues....
I tend to go with that if you understand what is happening when the engine is running you won't let it run long enough to do any harm. That's why some have never had a problem. It's the people who have no clue as to what is going on down there that imho tend to have all sorts of problems with their machines. |
behindpropeller
If you want to see if it turns over in your driveway, pop the cap off of the coil.
My guess is that your prop is turning when you start it in nuetral, and the shaft is rubbing on the cutlass bearing. |
