need perfect pass help |
Kenny Wesley
Newbie Joined: April-14-2005 Location: United States Status: Offline Points: 2 |
Posted: July-13-2005 at 3:30pm |
Does anyone have a source for rebuilding the servo unit or anyone have a used one for sale?
Mine has siezed up, perfect pass says buy a new one. |
Kenny
Art
Guest |
If you can get the four Phillips head screws out of the motor without twisting them off, you're on your way to repairing it. Make sure you have a proper fitting screwdriver before you try. Maybe put some penetrant on the threads at the other end of the motor and let it soak in for a couple of days.
Once you get the end cover off the motor, press out the armature, then clean the corrosion off the stator magnets and the armature with a nonmagnetic wire brush. (I use a brass brush that looks like a big toothbrush) Blow out with high pressure air if possible. Your problem was caused by the motor getting wet, be it from condensation or otherwise. Art |
markski
Newbie Joined: August-18-2005 Location: United States Status: Offline Points: 4 |
i have a complete 01 perfect pass for sale $400
Mark Prendeville 518-623-3235 Wakeboard Pro model |
