Python 502 Manual |
skiguy
Newbie Joined: August-16-2007 Location: United States Status: Offline Points: 15 |
Posted: November-23-2008 at 3:38pm |
Does anyone have a lead on finding an engine manual for a 1999 502 Python. Thanks in advance.
WakeSlayer
I am pretty certain you will not find one. There are a couple footnotes in the manual for whatever model you will have.
What are you looking for specifically? I can make copies of what there is , if you like. They were not popular enough to justify a whole different manual. Python Power! |
Mike N
1968 Mustang |
skiguy
I appreciate your response. I am not a mecahnic but can do basic things like oil changes and minor repairs. Right now I seem to have a bit of dripping coming from one of the big circulating hoses on the front of the engine..the big fat one that goes into the impeller. Basically I need to find out the part Name and # so I can hopefully order a new one. Thanks Again.
sg,
On a 99, the rubber hose should still be good. Have you tried removing the hose, cleaning up the connection areas and putting it back on? Also. when tightening hose clamps, use a hex driver or a socket. (I believe it's a 5/16") You will get even and more torque to tighten them than using a screw driver. |
skiguy
That's good advice especially coming from the G.P. on cleaning and retightening. It is a small drip and the hose looks good. In fact I can't find out exactly where it is coming from as there is no visible damage to the pipe.
WakeSlayer
Go through all your hose clamps with a nutdriver. Most of mine were loose a couple years ago when I first bought the boat.
Mike N
1968 Mustang |
